Old 06-28-2013, 09:06 PM   #491
1999 25' Safari
Somewhere , Ohio
Wow, that was close!
Speaking of storms, our weather forecast for the next 14 days has storms forecast for every day, and we've already had that for the past four or five. That certainly cuts down on the polishing!
Deb
Air Cruiser is offline   Reply With Quote
Old 06-28-2013, 09:18 PM   #492
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Originally Posted by HiHoAgRV View Post
Geez that's close. The heat is kicking in high gear down south so I'm not making much progress on Dolly. Well, that and too many other projects!
What kind of heat do you generally have at this time of year? I've been to the Florida Keys in June & there was no way anyone could ever polish in those temperatures!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-29-2013, 05:12 PM   #493
Central , Mississippi
It's not really super hot that gets us, its the soak. Our pool is 90 degrees and will probably top out at 95+ in late july. It just doesn't cool off for about 3 months. Getting an early start helps somewhat but 1st thing in the morning is usually the peak humidity. By 9:00 this morning all of my clothes were soaked with sweat.
I'm ready to put some hours on that new 15000 AC unit...time to go camping!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-09-2013, 09:14 AM   #494
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
My hubby plumbed the grey tanks to the shower pan today. He's going to run the grey water from the kitchen sink in with the vent on that side of the trailer, so this is all the plumbing that will be under the trailer. We used a Hepvo drain on the shower so we don't have to have the p-trap hanging out of the bottom of the trailer.
Becky-
How high up on the sides of the gray tanks did you have VTS install your inlets? I am getting ready to put the floor in where the gray tank could go and I am trying to figure out if I should put the connector plate (shell on floor install, remember!) on top of the floor or underneath like the rest of them.
Placing it above, presumably I could place the fresh water tank on it...and lose a bit of interior cabinet space. Placing it underneath, I would need to lower the inlet a bit on the tank...didn't know if that mattered? It looks to me from your pics that your inlets are pretty much centered in the tank sides. Is this correct? Perhaps it does not matter how high up it is. I thought the higher up it was the more capacity it would have, but I am now thinking water doesn't care.
Thanks! I will post some pics of my progress this evening.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 07-09-2013, 08:02 PM   #495
Becky B.'s Avatar
1964 17' Bambi II
The tanks come with one hole installed already by VTS. It's low on the tank and in the center of the tank. We had one extra one put in the same spot except on the opposite side of the tank for the shower drain to tie in. The galley sink drains to the top of the second tank & the first tank (closest to the front of the trailer) is vented out the top & ties in with the galley sink, which ties in with the vent stack in the closet. Make sense?
Here are some pictures of the rear grey tank tied in with the shower drain:
Becky
1964 Bambi II
1988 Avion 32S
Old 07-09-2013, 08:23 PM   #496
1964 17' Bambi II
Attachment 190621
Attachment 190622
So the added holes were placed low on the tank? Cool.
Is venting necessary? I heard it is and then that it is not. I guess if it is vented it drains more quickly?
Ben
Old 07-09-2013, 09:15 PM   #497
Becky B.'s Avatar
1964 17' Bambi II
From everything I've read, it's necessary. It drains more quickly as well as more completely, not to mention it lets the nasty smells out through the roof instead of wafting around your trailer :-/
Becky
1964 Bambi II
1988 Avion 32S
Old 07-10-2013, 11:34 AM   #498
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Wanted to second this... Definitely necessary. You don't want to create a vacuum when emptying or put so much pressure when filling that it slows the process and creates "burps".
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 07-11-2013, 03:13 PM   #499
Becky B.'s Avatar
1964 17' Bambi II
I'm going insane polishing.... My hands & arms kill, I've been mocked by my daughter, I need more ibuprofen, but I'm maxed out, I obviously need a shower.....
Becky
1964 Bambi II
1988 Avion 32S
Old 07-11-2013, 03:28 PM   #500
1959 17' Pacer
But I see something shiny in the background....Isn't it worth it?!
- Peter (and Marie)
TAC CA-15
Old 07-11-2013, 03:43 PM   #501
Becky B.'s Avatar
1964 17' Bambi II
It will be after I recover....:-) I have a goal to finish it this week, but its killin' me!
Becky
1964 Bambi II
1988 Avion 32S
Old 07-11-2013, 04:33 PM   #502
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Keep it up! It's worth it!
Lance
Top is offline   Reply With Quote
Old 07-11-2013, 04:43 PM   #503
Becky B.'s Avatar
1964 17' Bambi II
I just felt the need to whine. Some of the other kind of wine might help loosen things up!
Becky
1964 Bambi II
1988 Avion 32S
Old 07-11-2013, 05:33 PM   #504
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
That's a great look!
desertair27 is offline   Reply With Quote
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 04:08 PM
