Old 02-07-2013, 08:16 PM   #365
reinergirl's Avatar
Hollis , New Hampshire
I agree with Barbie as to the stiles.
As an alternative ( and I'm going to have trouble explaining this) what if you made a solid non moving panel at the front of the bottom of that closet, say from the countertop level down. Regular cabinet door just like your others above. Sure you'd have to reach down into it to store things but it could work. You could even build a decorative panel into the center of it, like the metal one you have to the right. What's below the closet , can't quite see it?
Or maybe a solid panel with holes for wine bottles, Or open cubby holes for ?
reinergirl is offline   Reply With Quote
Old 02-07-2013, 08:35 PM   #366
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I'm so glad to hear from women on the cabinet subject....so cool to not be the only female who does woodworking (my friends think I'm rather odd & eccentric, I think!) I will take both of your advise & use the 1 1/2" styles, to keep things uniform. Shelly, I did think about bringing up the bottom panel to counter level. The only problem with that would be if we have any issues inside the closet bottom. We have plumbing, gas & the water heater all below the closet floor. It would be tuff the get down there if we had another 18-20" to bend over & into the bottom of the closet. I could test it out with a board tomorrow & see how far this old body can bend into there -- even though it would be my DH who would be diving into the closet of anything mechanical goes wrong!!! Thanks, girls, for the opinions!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-07-2013, 08:51 PM   #367
reinergirl's Avatar
Make the panel removable. Kreg jig joints (as long as you don't glue) can be removed and reassembled very easily. Or do two backing boards on either side and attach the front board with those super strong mini magnets recessed into the face. Try Rockler as a source ! I also love to see other women who woodwork!
On reflection it was Lee Valley where I got magnets
http://www.leevalley.com/en/wood/pag...=1,42363,42348
Old 02-07-2013, 09:05 PM   #368
Becky B.'s Avatar
1964 17' Bambi II
I have Kreg joints all over the place, so the removable panel is a GREAT idea. Then I can make the door match the others. Now I can sleep. Thanks!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-07-2013, 09:12 PM   #369
reinergirl's Avatar
You're welcome !
Old 02-08-2013, 12:28 AM   #370
webspinner's Avatar
Menlo Park , California
I really like the idea of the bifold door. It's a unique enough cabinet that it doesn't have to look exactly like everything else, and the different opening mechanism justifies a slightly different look. Keeping access easy is important, 'cause when you need access, you usually need it right now.
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 02-08-2013, 07:37 AM   #371
1999 25' Safari
Somewhere , Ohio
Hi Becky.
I agree with the others about the size of the stiles.
I was wondering if you'd considered doing "sliding bi-pass" doors there? (One slides in front of the other one when open, and they just lift on and off when you need to do major things inside.) That way you don't have to worry about the stack-back of the two doors bumping into the adjoining cabinets. They are super easy, just build the doors and then hang them on hardware you purchase at HD, or where ever - they glide very easily............which, come to think of it, could be a problem with movement during travel, you'd need to place a stop for travel time.
Everything's looking so good! Great job.
Deb
Air Cruiser is offline   Reply With Quote
Old 02-08-2013, 12:26 PM   #372
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Becky
Beautiful cabinet work. I understand why you made the drawers come out so far to the edge. 1 1/2" styles I agree. I like the idea of a removable door too. Bifold doors are problematic and will just get in the way when you want to access the cabinet. A removable door will make the best access to the cabinet interior.
Dan
TouringDan is online now   Reply With Quote
Old 02-08-2013, 02:16 PM   #373
Becky B.'s Avatar
1964 17' Bambi II
I just ran out & took a measurement of the opening: It's only 21 3/8". So, if I were to put sliding bi-pass doors (which is a nice idea), the opening would only be half of that. I still don't mind the bi-fold idea, with a removable panel on the bottom up to the counter, to square things off so the frame of the door can sit outside the opening. I am afraid a complete solid door would get in the way when opened, because you'd have to deliberately step past it to open it up. The original door was a bi-fold. (not that anything is original in this puppy). Thanks everyone for all your ideas. I think it'll be a melding of all of them!
I got my fabric today. Quite an exciting thing! Now to call the upholsterer....I know my limitations, and that my friends, is NOT up my alley!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-10-2013, 08:27 AM   #374
Machinist
Blondin's Avatar
1971 31' Sovereign
Yakima , Washington
Looks great!!!!!!! It's been great watching the progress!!
Keep up the great work!
-Mark-
Blondin is offline   Reply With Quote
Old 02-12-2013, 02:01 PM   #375
Becky B.'s Avatar
1964 17' Bambi II
ID:	178849Got my upper cabinets hung today. Another first for me! Yesterday, I ordered my foam for the gaucho & dinette. Oh wowza!!! I got a fabulous deal on the fabric at a huge place in Chicago (2121 21st Street, Textile Outlet), but had the foam ordered from my buddy who did the gaucho in my '86 when I had it redone (he does really nice work if anyone needs stuff done & lives in the Chicagoland area). Anyhow, that foam is pretty pricey stuff! So, here are some pix of the upper cabinets:
Becky
1964 Bambi II
1988 Avion 32S
Old 02-12-2013, 05:25 PM   #376
1999 25' Safari
Somewhere , Ohio
Cabinets, as well as everything else, look super! Would you mind sharing how you hung the cabinets, or rather, what they are attached to and how? My DH says he doesn't know if he wants us to hang anything from the ribs because he doesn't think they are that substantial. I'm thinking all of ours may have to be build up from the floor, if that makes sense.
Did you have the original cabinets to use to get the correct arc/curve of the ceiling/walls?
Thanks Becky.
Deb
Old 02-12-2013, 06:32 PM   #377
Becky B.'s Avatar
1964 17' Bambi II
Thanks Becky.
Deb
I had nothing to use as a pattern. The original cabinets weren't in the trailer when found. I scribed the walls onto a piece of scrap & cut it , tried it, cut it, tried it (you get the idea) I got some ideas for hanging from this thread:
http://www.airforums.com/forums/f7/k...g-90350-3.html
I made a cleat on the underside of the cabinets that holds the bottom up & also put cleats on the sides for holding it up there. I attached the cleats to the aluminum walls with riv-nuts. I had a piece of aluminum bent to match the angle of the ceiling to the angle of the front of the cabinets & hung it from there too. Vernon had a good idea of making a small "scaffold" to use under the large cabinet. That really helped me out (since I hung it myself) and kept me from having to hurry while installing them. I think I could hang my body from them & they wouldn't fall. They're really secure up there!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-13-2013, 08:25 AM   #378
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Becky, I like what you have done with the cabinet over the range top. My head catches the corner of my cabinet at least once each trip. Starting to get some pretty good scar tissue built up.
MICHAEL
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 04:08 PM
