Old 12-06-2012, 11:30 AM   #323
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I finished laminating the galley last night. Routing isn't my favorite thing...could be that I'm forever damaged by witnessing my sister-in-law turn the end of her finger into hamburger while routing!! (back in the good ol' days we had a little wood craft business). Anyhow, there was much routing to be done, but I'm now finished with laminating!! Yee haw! This morning I attached the sink (while in the house..much more comfortable than trying to cram under the counter) and the stove. My son was the extra pair of hands while installing the gas on the tiny stove. Now comes the fun part of blinging it up with some silver trim. I like that part!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-06-2012, 09:45 PM   #324
Central , Mississippi
Have you selected a counter edge trim? I'm hung up on a fluted or a plain...neither are available locally to I get to pay 1.5X the cost for shipping...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-07-2012, 06:56 AM   #325
Becky B.'s Avatar
1964 17' Bambi II
I chose the plain. What really stinks is that I ran short & had to order it again! :/ I also ordered trim for the floor & counter top edges in silver & had to pay bookoo bucks for that shipping. Oh we'll.... Whatcha gonna do?
Becky
1964 Bambi II
1988 Avion 32S
Old 12-20-2012, 12:46 PM   #326
Becky B.'s Avatar
1964 17' Bambi II
In little bits of time over the last couple of weeks, I've finished the top of the galley, installed drawers (oh my, what a PITA!), varnished the drawer fronts & a couple doors.Click image for larger version
I'm using the aluminum front in the rear cabinet so the a/c can move air. I like the look so much, that I might use it on the upper cabinet doors.Click image for larger version
ID:	174921 I installed the drawer fronts in the rear, only to figure out that one of the drawer fronts wasn't square I can't believe I did such a kindergarten mistake, but I am only in first grade! So, now I have to glue up some more boards, because I used them all. Oh well, always something to frustrate myself!
I've also admitted defeat in finding any kind of stick on edging for the wet bath & have used my secrets of caulking all around the wet bath. Two & a half tubes later, it doesn't look half bad.Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 12-20-2012, 01:53 PM   #327
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Smev Hob
Looks like you chose a Smev Hob for your stove, as did we. We had to raise the counter level above the frig in order to get the safe air space between the Dometic and the Smev. So the stove area is a couple of inches higher than the sink.
Our Smev igniter was supposed to use a trailer 12 volt line for power but there was no wire close by. I didn't really want to run a wire clear from aft just for an igniter. I ended up wiring the igniter to a little 9 volt battery. Work great!
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, '11 Touareg TDI
Santana tandem bike
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 12-20-2012, 02:57 PM   #328
Becky B.'s Avatar
1964 17' Bambi II
Our stove doesn't have an electronic ignition, so that was one less thing to wire! Pretty smart to wire it to a 9 volt battery. Since we had no cabinetry, I raised the whole thing to accommodate the stove/refrigerator specs. According to the manual, "from the lower part of the appliance to the wall underneath 30mm, 1 1/4" " I also put a metal partition in there, as well as insulation under the metal partition to keep heat from the refrigerator. The top of the cabinet sits level with the window sill in the galley. Also, I'm a lefty, so I put the sink all the way to the right, so I have a working area to the left of the sink.
I like your Bambi II, Antique Pedaler (sorry I don't know your name). It's really very nice!
Becky
1964 Bambi II
1988 Avion 32S
Old 12-20-2012, 03:35 PM   #329
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by beckybillrae View Post
In little bits of time over the last couple of weeks, I've finished the top of the galley, installed drawers (oh my, what a PITA!), varnished the drawer fronts & a couple doors.Attachment 174920
I'm using the aluminum front in the rear cabinet so the a/c can move air. I like the look so much, that I might use it on the upper cabinet doors.Attachment 174921 I installed the drawer fronts in the rear, only to figure out that one of the drawer fronts wasn't square I can't believe I did such a kindergarten mistake, but I am only in first grade! So, now I have to glue up some more boards, because I used them all. Oh well, always something to frustrate myself!
I've also admitted defeat in finding any kind of stick on edging for the wet bath & have used my secrets of caulking all around the wet bath. Two & a half tubes later, it doesn't look half bad.Attachment 174922
http://flexiblemouldingconcepts.com/...g_Complete.pdf
Old 12-20-2012, 05:51 PM   #330
Becky B.'s Avatar
1964 17' Bambi II
Thanks for the link, Aerowood. I'll check it out!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-14-2013, 08:48 PM   #331
Becky B.'s Avatar
1964 17' Bambi II
Between the holidays & a family vacation, the Bambi II project has been a little slow! I have managed to frame in most of the upper cabinets. I have shortened the cabinet on the curbside. I have whacked my head enough on my '86 Sovereign while entering & making a quick left that I KNOW it'll be a problem for me in the little Bambi II! I'm going to make some nice things to hang around the refrigerator vent for holding spices, etc. when I have nothing else to do! I want to thank Vernon for his good idea of making a "scaffold" for holding up the cabinet on the streetside while working on it. I still have to complete that giganticly long cabinet, but it's getting there! Kinda crummy pictures from my phone....oh well!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-14-2013, 09:32 PM   #332
reinergirl's Avatar
Hollis , New Hampshire
Looks great!
reinergirl is offline   Reply With Quote
Old 01-14-2013, 09:37 PM   #333
Thats a BIG cabinet!
Old 01-18-2013, 08:34 PM   #334
Becky B.'s Avatar
1964 17' Bambi II
I finished the framing of the upper cabinets this past week. Got them varnished & installed. Also, I installed my speakers for my stereo system. It's a lot of speakers in a small space, I know! There will be a floor above all the wire mess & the tops of the speakers will be popping out in the cabinet. I'll probably make a little box to go over them. So, if my trailer is a rockin' don't come a knockin'--cause I won't hear you-- The task lights above the sink also have been installed. Next, I'll have to bribe someone with a wiring brain to hook all this stuff up for me!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-18-2013, 10:36 PM   #335
Becky B.'s Avatar
1964 17' Bambi II
I should clarify "rockin' " meaning rock & roll....!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-18-2013, 10:52 PM   #336
reinergirl's Avatar
Sure Becky, sure.....
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 10:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 08:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 05:08 PM
