Old 03-02-2012, 06:45 AM   #211
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I attached it with aluminum tape (they have it at the big box stores). The sides I fit between the ribs & taped them to the sides of the ribs & the endcaps I had to cut numerous pieces & taped the edges down before I put the next piece on. I went through quite a bit of tape--I happened to find a bunch at Big Lots for about $5 a roll. I put a very thin foam tape along all the edges of the ribs to have a barrier from the exterior cold coming through those. I poked holes in the foam tape where the rivet holes were so I could find them when I put the walls back in. Worked out pretty well.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-04-2012, 12:42 PM   #212
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Originally Posted by beckybillrae View Post
I used the sawzall to get the black tank/toilet all the way out. I removed an access pan from under the trailer & then cut both sides of the dump valve (actually, I conned my son into sawing it for me) He tried to loosen the nuts on either side, but it was not going anywhere. Both pieces are fiberglass, not plastic. They both survived & I'll be reusing them.
Becky-
I finally got some time to work on the AS yesterday. Guess what ...bathroom removal! My shower pan came out fine (drain was already removed using an open ended wrench and a screwdriver for leverage).
Toilet came out fine (I could get to the rear bolt and with a gear wrench, it worked well).
I broke both studs holding the toilet flange on to the tank. Is there a way to replace these? Looks like the metal piece these came out of are embedded in the top part of the tank.
I have also been soaking the lower drain valve bolts with PB Blaster. I hope to remove the nuts and be able to then get the black tank out of the trailer.
I plan on starting my own page soon...but it will not move along nearly as quickly as yours! We have a new reason to get this Bambi done now...we are expecting another baby in September! That 13' Scotty sure is looking small now!
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 03-04-2012, 02:08 PM   #213
Becky B.'s Avatar
1964 17' Bambi II
[QUOTE=PA BAMBI II;1115195]Becky-
The studs broke on our toilet flange too. I ground them off flush with the pan. My husband found a toilet flange at his favorite plumbing place that fits directly into the existing hole. He's going to glue it in there when we get to that point. The new toilet comes with bolts that fit in the flange. If you're keeping your toilet, you'll have to get a new flange to fit in the hole & get some bolts that slide in the holes. I'll get some pictures of the new flange for you.
We yanked the black tank with the lower plumbing attached. It was so long ago that I can't remember exactly how we got it off. It was heavy, that much I know! I can take a picture of our plumbing configuration for you too (I don't know if you're putting in a grey tank, but it's plumbed for that) It's attached to the bottom of the black tank already for when we get to that point. I say "we" cause I'm no master of plumbing!
Congrats on the baby! You might want to look for something bigger than a Bambi II!!
Becky
1964 Bambi II
1988 Avion 32S
Old 03-04-2012, 02:35 PM   #214
Becky B.'s Avatar
1964 17' Bambi II
Did some "hillbilly chrome" on the interior window cranks & frames:Click image for larger version
Name:	window latches redone.jpg
When I removed the interior refrigerator vent it was very brittle. The edges were cracked off in many places. I saw someone on the forum used fiberglass & black gasket glue to beef up the edges. I did it & it worked well. I then painted the inside of the vent with fiberglass resin to give it some firmness & that worked well too. I plan on putting an aluminum trim over the edge where it shows (cause it's not too beautiful as is!):Click image for larger version
Name:	fixed edge 2.jpg
Name:	fiberglass resin.jpg
I sealed it to the wall with Vulkem. Hopefully, I'll NEVER have to take it off!
I made some patches for the holes left by the original lights. I'm putting the crank for the antenna & a light (with a switch by the door) in the front, and a light in the rear. Something a little more modern than what was in there:
Front patch:Click image for larger version
Name:	front light patch.jpg
Rear Patch:Click image for larger version
Name:	rear light patch.jpg
Becky
1964 Bambi II
1988 Avion 32S
Old 03-04-2012, 02:40 PM   #215
Becky B.'s Avatar
1964 17' Bambi II
I attached the new wheel wells that I had fabricated at a heat/air conditioning shop:Click image for larger version
Name:	new wheel wells.jpg
And primed the interior:
Name:	interior primed 1.jpg
Name:	interior primed 2.jpg
Name:	interior primed 3.jpg
I used Zinsser oil based primer tinted grey. I'm going to use a pewter colored paint by rustoleum that has some sheen an a bit of texture to it.
Becky
1964 Bambi II
1988 Avion 32S
Old 03-04-2012, 05:33 PM   #216
Central , Mississippi
HVAC wheel wells...what a great idea!
Glad to see your progress...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-04-2012, 11:13 PM   #217
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looking good Becky! I wish it was warm enough to do some painting here, everything is still a little white and frozen outside!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 03-05-2012, 04:42 AM   #218
Ludowici , Georgia
Images: 43
bambi 2
u don't see THAT every day!!
I agree, SWEET tractors. Looks like you have your work cut out for you, but great find! Glad it found a good home![/QUOTE]
good find and good save I also got my first airstream saturday 31 ft sovereign land yaught
Stoney is offline   Reply With Quote
Old 03-05-2012, 04:44 AM   #219
Ludowici , Georgia
Images: 43
got my first airstream this weekend 31 sovereign land yaught
Old 03-05-2012, 05:33 AM   #220
Becky B.'s Avatar
1964 17' Bambi II
Congratulations to you & welcome to the forums! My other trailer is an '86 sovereign....lots of room in her! Bambi II.....not so much
Becky
1964 Bambi II
1988 Avion 32S
Old 03-07-2012, 07:23 PM   #221
Becky B.'s Avatar
1964 17' Bambi II
Black Tank Plumbing
As I promised Ben (Pa Bambi II), here are some pictures of how we dealt with the black tank plumbing. We used a piece of solid plastic (like what a cutting board is made of) between the tank & first fitting. The pictures should speak for themselves:Click image for larger version
The white fitting is part #IF338
Becky
1964 Bambi II
1988 Avion 32S
Old 03-07-2012, 07:46 PM   #222
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Wow, what a great project, and great problem solving.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 03-08-2012, 05:19 AM   #223
1964 17' Bambi II
Looks great, Becky! What Valterra valve part did you use? I saw the tutorial on Vintage Airstream on how to do this, but the internet is so thick with Valterra fittings, I cannot find a good candidate. What is the part number and who did you order it from?
Thanks! Keep up the good work!
Ben
Old 03-11-2012, 06:55 PM   #224
Becky B.'s Avatar
1964 17' Bambi II
The Valterra valves were in this link--we got them from Amazon.
T1010
1005-1
T1003VPM
Amazon.com: Valterra T1010 3" San Tee Reducing with 3" Bayonet x 3" and 1-1/2" Rotating Flange: Automotive
Becky
1964 Bambi II
1988 Avion 32S
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 04:08 PM
