Old 12-13-2011, 07:09 PM   #183
Central , Mississippi
Geez, I LOVE those 'luminum endcaps...(sitting here GREEN with envy...)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 01-27-2012, 02:25 PM   #184
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Sooo....I've been looking for aluminum trailera out here & all I can find are tin roofs! Enjoying the warm weather, but progress in the Bambi II has come to a screeching halt!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 01-28-2012, 06:07 AM   #185
tinman54's Avatar
1954 25' Cruiser
Cruisin , Wisconsin
Looks like all you are missing is the Bambi sitting out there under the palm trees. The other guests could help you polish it!
It's not worth doing if you're not having fun.
http://tinman54.blogspot.com/
http://www.airforums.com/forums/f228...tml#post616014
tinman54 is offline   Reply With Quote
Old 01-28-2012, 03:44 PM   #186
Becky B.'s Avatar
1964 17' Bambi II
I'm afraid she's sitting in a pile of snow back home. Poor girl--she's so neglected right now. I have no remorse--I have only a few more days to bake in the tropical sun--then back to the old same ol same ol. The salt air would be bad for the polishing anyhow!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-28-2012, 06:34 PM   #187
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hawaii, or the Carribean?? Looks great... and warm!!
Marc
Old 01-28-2012, 11:10 PM   #188
Becky B.'s Avatar
1964 17' Bambi II
Warm, sunny Punta Cana, Dominican Republic.
Becky
1964 Bambi II
1988 Avion 32S
Old 01-29-2012, 05:56 PM   #189
Old 02-01-2012, 04:16 PM   #190
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Removing Shower Drain- & toilet removal question
Originally Posted by beckybillrae View Post
I got everything but the shower pan & black tank out this afternoon. Any suggestions as to how to get the drain out of the shower pan? It's the only thing holding the pan in. Is there some special tool that hooks in the "x" in the drain to turn it? My husband couldn't get it to turn.
I used a 9/16" wrench and a screwdriver to get the shower drain out. I used the open end of the wrench to straddle the "X" of the drain and used the screwdriver to turn the closed end. Mine turned pretty freely and I did not break the "X". Now I need to remove the plethora of rivets holding the shower pan and black tank to the wall and remove them. The gutting is almost complete!
How does one remove the toilet from the black tank? I can't see that I will be able to remove the rivets behind it without removing the toilet.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 02-01-2012, 08:07 PM   #191
Becky B.'s Avatar
1964 17' Bambi II
Ben
I'm pretty sure my toilet wasn't original. It was plastic. It had bolts holding it to the black tank. Once they were loosened, it came off. I broke mine to bits, though! I have a nice, clean, porcelain one waiting in the wings! You need to post some pictures of your progress, Ben!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-04-2012, 04:29 PM   #192
Becky B.'s Avatar
1964 17' Bambi II
Well, the vacation is over .....so it's time to get back to the old Bambi II. I started fiberglassing & sanding & bondoing the black tank/toilet platform and the shower pan last spring. Figured it was time to finish that job, since I was waiting for my DH to help me (actually DO) the electric. I got some Por-15 Whitecote paint that I also plan to use for the shower walls. It came out pretty good...not perfect, but not too bad for a first timer. I don't think auto body work is my calling, however! My house really smells like strong paint. Hopefully there won't be any (more) brain damage!Click image for larger version
ID:	150308Click image for larger version
I enlisted the help of my DH again to help me put the end caps back up & start with the walls. It has gone suprisingly well. Thanks, Vernon, for the tip about putting the 73" stick with styrofoam on the end to prop the end caps up. It worked great![ATTACH]Click image for larger version
Do you think I've demanded enough power lines for the little Bambi II? I like gizmos & stereos & switches, so there are lots of wires. Sadly, I am not much at electric, but my husband has humored me & wired all of it. Thanks, Bill!Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 02-12-2012, 07:48 PM   #193
Becky B.'s Avatar
1964 17' Bambi II
I decided the front lower wall was too far gone to patch. The mice/rats/raccoons chewed the bottom of the wall for whatever reason (I think to make their super highway faster!) & it was just gross! The added bonus is that I can polish the whole front While I worked on that, my hubby hooked up all the outlets so I don't have to trip over cords anymore
The gnawed piece:
ID:	150956Click image for larger version
All the walls in:
Next is beginning to polish the endcaps. They are surprisingly corroded on the interior. At least the bottom will be easy! I want to have the buck rivets on the door be silver, so I'm going to prime/paint & move clecos around & rivet the door after painting. Should be interesting!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-13-2012, 08:45 AM   #194
Well that's interesting, 1 piece of metal all the way across. My '63 is 3 pieces. Ya gotta love new metal!!!
Old 02-13-2012, 12:35 PM   #195
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Interesting. Mine is 3 piece in the rear, one piece in the front. Go figure.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 02-13-2012, 07:47 PM   #196
Becky B.'s Avatar
1964 17' Bambi II
Mine was also 3 pieces in the rear. In some places it was 3 layers thick, with a piece of scrap from, what I'm assuming, was a '63 Bambi (the cut out was where it was on the '63) I can't say that this trailer was a piece of artwork when it was made. There were ribs that didn't make it all the way to the floor, ribs that were only atttached on one side, the frame had a cut out so the plumbing could make it through....stuff like that. I laughed as I was busy riveting the other day. I remembered reading here about people complaining that there were rivet shavings, rivets, miscellaneous scraps in their trailers from when they were made. If you've ever completely put a trailer back together, you sure can see WHY there might be some stuff here & there! It's a pretty messy business & clean-up is a big part of the putting back together!
Becky
1964 Bambi II
1988 Avion 32S
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 04:08 PM
