Old 11-27-2011, 06:54 PM   #169
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I'm Reaching Insanity QUICKLY!
I've been trying to track down leaks for what seems like weeks now!! I thought, since I sealed the interior, that I would have caught all the leaks without having to seal the exterior. WRONG! So, I decided to seal the exterior & take care of all the leaks. WRONG! I think I have to go around every single rivet with sikaflex or tempro. The problem is, I've sealed the interior seams. So, if a rivet is leaking, I can't see it because it runs down the rib, from who knows where, and ends up on the floor. AAAHHH!!! I'm exasperated & want to jump up & down & scream. Just venting.........
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-27-2011, 07:11 PM   #170
Central , Mississippi
Leaks are bad...one of my leaks is a rivet...and it FILLED a cup last night.
What do you think of making a round hole in maskin tape and using it to seal each rivet with Tempro?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-27-2011, 07:24 PM   #171
Becky B.'s Avatar
1964 17' Bambi II
My '86 Sovereign had a million leaks too. I just took the Tempro & swirled it with my finger around the rivets & cleaned them up with Mineral Spirits. It worked. I just am so fed up with these leaks. I guess I have to bit the bullet & just go after all the rivets. I'm cherry picking them now & that's not working for me! I worked all afternoon to try & find these leaks. I think, by trying to stop things up inside, that the water just works its way out somewhere else. I'm so ready to move on to insulating, but I can't till I find these stinkin' leaks My leaks certainly don't fill a cup....they're very tiny & seep just a little. A cup is a TON! By the way, were you deer hunting?
Becky
1964 Bambi II
1988 Avion 32S
Old 11-27-2011, 08:04 PM   #172
Originally Posted by beckybillrae View Post
... By the way, were you deer hunting?
deer...leak...hunting. Neither one is a sure thing, huh?
Old 11-27-2011, 08:17 PM   #173
Becky B.'s Avatar
1964 17' Bambi II
no wonder you were in such a hurry to get your interior walls in.....I know, I'm married to a hunter....the hunting trip supersedes all else! (all the menfolk are out hunting pheasant in SD or ND (not sure which) right now) I'm so far behind now!!!
Becky
1964 Bambi II
1988 Avion 32S
Old 11-27-2011, 08:29 PM   #174
It's been 2007 since I was able to tow into the camp, I was really looking forward to it...of course it rained BUCKETS last night...
We stay on a bluff 40' above the river....
My pal has a new-2-him '74 tradewind....and want's to commit at least 20 hours to makin' it perfect...
So...what's the down side to NOT sealin' the bullit clearance lights?...lots of grease?
Old 11-27-2011, 08:37 PM   #175
Becky B.'s Avatar
1964 17' Bambi II
20 hours...perfect? Good luck!
Lots of grease...that's the ticket! (at least I hope so, since mine are swimming in it!)
Glad you're above the river. Good luck w/the deer. My DH & sons hunt those as well!
Becky
1964 Bambi II
1988 Avion 32S
Old 11-27-2011, 09:00 PM   #176
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Another way to seal rivets. Get a spray can of exterior lacquer, spray the rivet and wipe off the surface. The lacquer will soak in around the rivet and seal it.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 11-27-2011, 09:12 PM   #177
Becky B.'s Avatar
1964 17' Bambi II
Is exterior lacquer the same thing as clear coat? How long does it hold up?
Becky
1964 Bambi II
1988 Avion 32S
Old 12-07-2011, 06:57 PM   #178
Becky B.'s Avatar
1964 17' Bambi II
I have FINALLY tracked down all my leaks. A couple were where I sealed, but for whatever reason (dirt behind the caulk, mostly) they didn't seal well. So, I could move on to insulating. I chose Prodex again. I used it previously in my Sovereign's belly pan rehab project & could definitely tell the difference when I ran my air conditioner. I've finished one layer so far. Tedious, but mindless work! I'd hate to do a 31 footer! So, here's the obligatory pictures.....
The Front:
The Rear:
Becky
1964 Bambi II
1988 Avion 32S
Old 12-07-2011, 07:23 PM   #179
That looks GREAT! Taping the Prodex turned out to be my least favorite part of the entire rebuild to-date...
Tonight I was installing interior skins...it's 36 degrees outside...one small cube heater in Dolly and I was sweating! Prodex is working great so far...
Old 12-07-2011, 08:16 PM   #180
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
[QUOTE=beckybillrae;1080860]I I chose Prodex again.
Where does one get this Prodex? Looks more fun to work with than fiberglass...
I wish I could get to work on my Bambi II! Perhaps this Winter I can finish gutting it. I am at the point where I am going to have to get the shower drain out. I'll have to read your history on how to do that.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 12-07-2011, 08:56 PM   #181
Becky B.'s Avatar
1964 17' Bambi II
I think this is the only place you can get Prodex from:
Prodex Total 24 Inch Insulation
I've finished my first roll & am into the 2nd. I used the first under the floor, so I hope to have enough to finish the 2nd layer.
Also, just for all the bargain shoppers, Big Lots by my house has rolls of aluminum tape for $5. It's $11.50 at Menards, so that's quite a deal! I'm through 6 rolls so far.....
Becky
1964 Bambi II
1988 Avion 32S
Old 12-12-2011, 03:42 PM   #182
Becky B.'s Avatar
1964 17' Bambi II
Last Mouse Highway!!!!
I started insulating the endcaps themselves yesterday (following HiHoArRV's lead--thanks Vernon). Finished the front one, but upon further inspection of the rear, there was so much corrosion from mouse whiz that I had to do something about it. While I really don't care about the inside of the endcap, I think that if it's not stopped it will keep corroding & may cause problems later. So, I used my handy dandy Matco polisher/right angle thingy and buzzed away at it. Then I put on a quick coat of clear coat to keep it from going anywhere (in theory). I'm letting it dry a while before putting the Prodex on it. Kinda a pain to put it on the cap when it's out--
I finally found a way to keep the endcap from jiggling everywhere....Thanks Tommy Bahama!
This is a small spot of the whiz/corrosion:
After sanding/polishing with my whizzer
One finished endcap....dreading the last one!
Becky
1964 Bambi II
1988 Avion 32S
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 04:08 PM
