Old 07-16-2011, 09:21 PM   #141
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Originally Posted by HiHoAgRV View Post
METAL ENDCAPS? WOW....I didn't know that was an option. Mine are huge chunks of fiberglass...
That's one thing that I hate about my '86 is the plastic endcaps. I just assumed all the early 60's had metal. Bummer for you!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-22-2011, 03:57 PM   #142
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Where to buy window seals?
Originally Posted by beckybillrae View Post
The windows all needed to be redone, so I had all the parts & pieces waiting in the wings (my basement has become the staging area for all my stuff!). I polished all the frames before reglassing them & then cleaned out the frames on the shell before putting in the new gaskets. The gaskets were a breeze! I've finished 3 windows & have 2 plus the door jalousy to go. Three of the major thoroughfares of the raccoon highway are officially CLOSED!
Hi Becky- Where did you get the gaskets for the side windows? VTS used to have the seal (I think), but I cannot find it now. I have one street side window to re-do. Because of budget, the rest will most likely be left well-enough alone. Let me know- I guess I need the tape for behind the glass, and the strips to seal the glass in. I als need to have the Hehr aluminum frame repaired- but I can get that done.
Did you order from VTS? If so, what part numbers?
Thanks! Ben
PA BAMBI II is offline   Reply With Quote
Old 07-23-2011, 03:21 PM   #143
Becky B.'s Avatar
1964 17' Bambi II
Hey Ben,
If you need to replace the window, you'll need this:
Butyl Glazing Tape
If you only need to replace the gasket that runs in the frame of the window that part of the trailer (as opposed to the window itself) you'll need this:
Hehr Window Bulb Seal
And finally, if you need to replace the grey plastic glazing that's part of the window, you'll need this:
Hallmark 12 Glazing Strip
The bulb seal is super easy to do. You just put it in the back side of the groove & then use a small screwdriver to run the front of it into the groove. It's nice & soft, so it doesn't fight you at all!
I'm working on my water heater door right now. I'm doing it like this:
http://vintageairstream.com/Images/h...terinstall.jpg
It has been so hot that I'm trying to do what I can inside my basement where it's cool!
Becky
1964 Bambi II
1988 Avion 32S
Old 08-03-2011, 09:50 PM   #144
Becky B.'s Avatar
1964 17' Bambi II
I've been working on the water heater door & the fantastic fan/hehr vent hybrid indoors lately. I also rebuilt the door by putting in Prodex insulation, new gaskets, got the lock keyed at the locksmith, and finished the jalousies. I've been reading about the "alumibrite" on the forums recently too. While polishing the original hehr vent cover, I decided the Bambi II needed an acid wash before I seal things up. I plan on polishing when I'm finished with the interior, but I'm kind of keeping it in mind when I put things back on. I'm rough polishing around lights, vents, etc. before I actually put them on so I won't have to get so close to them when I actually do polish. So, I road my Aprilia Scarabeo 500ie scooter off to NAPA today to get some acid wash. Finally a day that wasn't beastly! Gladly, I did it now & not later. It didn't get along with butyl tape or parbond. I had butyl tape around the water heater & it turned into black streaks. Same with the parbond that I had around the doorknobs. It cleaned up with some more acid on a rag.
ID:	136672   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 08-17-2011, 09:05 PM   #145
Becky B.'s Avatar
1964 17' Bambi II
This week was fairly productive. I installed the false door on the water heater (what a pain that "little" project was). I also installed the hybrid fantastic fan, the "Jack" tv antenna (not my favorite look, but I like to watch a bit of TV--sorry purists), two vent stack covers, and a vent in the rear of the trailer for the air conditioner. I plan on putting an a/c inside the cabinet in the rear of the trailer & cutting vents in the floor for fresh air circulation, along with a drain out the bottom. That'll come a bit later, though. I still need to install the radio antenna, a new refrigerator vent, and figure out what to do with the original battery door. I don't plan on using that space for a battery (I'll be using an AGM battery), so I either have to make a false door, a real hatch door, or a patch (don't really want a patch). Hummmmm.....
ID:	137961   Click image for larger version
ID:	137963   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 08-17-2011, 09:09 PM   #146
Central , Mississippi
Cool Progress!
I ran across one hickup in my plan - I need to add another 110V feed to the location where my converter will be located...
I WAS gonna run it on the GFI circuit that is right near the battery location...I discovered today that converters and GFI circuits don't play together very well.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-17-2011, 09:18 PM   #147
Becky B.'s Avatar
1964 17' Bambi II
I'll have to tell my DH that. He's putting on his electrician hat (along with his plumber's hat) when the project gets there. Those two things are totally Chinese to me. Installing fixtures--yes, I can--but wiring/running plumbing lines--uh, no!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-30-2011, 09:06 PM   #148
Becky B.'s Avatar
1964 17' Bambi II
I worked on the battery compartment today. I've decided to use the area for my 30 amp plug and the cable hook-up. I had to build framing because the battery box was plastic & it's now in the trash. So.....since I've never really done anything like this, it was a bit of a challenge for me. Thankfully, I've done a lot of woodworking & have plenty of tools. My bandsaw comes in handy for little cuts here & there! I'm going to put a plate of aluminum on the framing & mount a Marinco outlet & the cable thing directly to that. (yeah, that's my handy, dandy farmer seat on wheels outside. Pretty easy on the old buns!) Next step is to figure out how to make a door. Any good suggestions of tutorials?
ID:	141322   Click image for larger version
ID:	141326   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 09-30-2011, 10:19 PM   #149
65CV's Avatar
Western , Massachusetts
Just found this thread
Becky,
What a great thread and a great read! I can't believe I just found it.
Thanks for sharing your story. I look forward to following it.
I have an access door and frame from a '65 Caravel removed from the shell. Want some pics? Not sure it will match your frame design, but it might give you some ideas.
John
65CV is offline   Reply With Quote
Old 10-01-2011, 07:40 AM   #150
Becky B.'s Avatar
1964 17' Bambi II
Originally Posted by 65CV View Post
Becky,
John
I'd love a picture of your door if it's the kind that has a hinge. Mine are the hinge-free kind that come out when you unlock them. I want to make a door with a hinge & no lock because, first off, I hate those doors cause you always need a key to open them and I've read about tons of people losing them on the road, and secondly, there won't be access to the inside of the trailer, so it won't need to be locked. I think I might have to take the sheet of aluminum to a friend who has a break to have it bent to the right size.
Thanks for the offer, John!
Becky
1964 Bambi II
1988 Avion 32S
Old 10-01-2011, 01:00 PM   #151
65CV's Avatar
Not the kind with the hinge
Becky,
Sorry, but it is the kind of panel you don't like -- removable panel with key.
If you ever need one, Harbor Freight has a relatively cheap 30" metal brake. I used it a bunch.
John
Old 10-01-2011, 04:36 PM   #152
Becky B.'s Avatar
1964 17' Bambi II
Thanks anyhow, John. I did get my panel put in today. I'll think about the door while I do some other stuff. At least the water won't get in now.
I got called off work today, so I had a bunch of time to putz today. There were two large holes from the awning right next to the door. I put in a scare light instead of having big rivets or a patch there.
I also installed the rear lights & license plate holder. I need a buddy to help me with the running lights on the sides for buck riveting. My family is avoiding me now.....
The weld in the aluminum frame of my rear wind broke today when I opened the window. Bummer! I think my son does aluminum welding, so I can beg him to fix it for me!
My next project will be to patch the corrosion holes on the streetside. I actually bought another "Bambi" emblem on ebay the other day to put over the patch. Should look pretty good IMHO (and in my mind right now!)
ID:	141384   Click image for larger version
ID:	141386   Click image for larger version
ID:	141388   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 10-23-2011, 07:57 PM   #153
Becky B.'s Avatar
1964 17' Bambi II
A new patch for yet to be named Bambi II
I finally got around to making the patch for the corrosion on the street side. First I bucked the patch & then I polished it so it wouldn't be such a pain with the emblem in place. The emblem has posts that go through the skin & have to be held in place with little metal things that slide on (I know, technical word slips the mind). I will Tempro the inside so it will never leak! Boy, does new aluminum ever shine up easily. This old girl (the trailer, not me) will be quite a beast to polish. She has lots of scratches & pits. I guess that'll have to add to her character! The emblem says simply "Bambi" and not "Bambi II". The original emblem on the curbside also says "Bambi". I'm sure it was a leftover from the '63 model since mine is only #3 of the Ohio 1964 Bambi II. So, I just went with it on the streetside. Pretty lucky find on the old ebay, I think!
ID:	143502   Click image for larger version
ID:	143504   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 10-23-2011, 10:23 PM   #154
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Lookin good! We had just about every window on our 63 with cracked upper corners. The flaw seems to be that they only welded on the back, which let the entire weight of the window pry on that weld. I found a REALLY good aluminum welder and he welded it all the way around then ground the weld down carefully to match the existing outside profile. Much stronger now.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 10:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 08:00 AM
Bambi II (and many other AS) found in RV book PA BAMBI II 1964 Bambi II 2 02-24-2011 05:08 PM
