Old 08-19-2015, 01:21 PM   #1
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Bambi II mystery leak
One day it will rain and the Bambi II stays dry. On another day it will rain and there is a small puddle under the left side of the galley window. We can't spot anywhere water is getting in. everything around and above the window, inside and out, is dry.
Any one have any ideas where the leak source might be?
Presumable the direction of the rain hitting the trailer is a factor on whether water will leak in.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 08-19-2015, 01:48 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Could be coming in somewhere else and running down in the inner skin to the window frame. Maybe roof vent?
BambiTex is offline   Reply With Quote
Old 08-19-2015, 02:18 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I had migrating mystery leaks all over my Bambi II. Never did find most of them.
MICHAEL
Old 08-19-2015, 02:26 PM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
I was lucky. Sat in mine in a downpour and all the water stayed outside :-)
Old 08-19-2015, 06:06 PM   #5
1964 17' Bambi II
Laramie , Wyoming
Images: 11
I think all Bambi IIs are infested with Manihunis, the mythical Hawaiian dwarfs.
Antique Pedaler
Old 08-28-2015, 08:50 AM   #6
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
After tearing the Bambi II down to the studs and replacing pretty much everything and sealing the inside seams of the outer skins, I still have three aggravating leaks.
The most major one is the main door...with a new seal from VTS. I know I have to seal the door eyebrow better (water runs down behind it and it is supposed to stop the water from getting to the door seam). I am considering fabricating and adding an oversized eyebrow (deeper than original) to keep more water from the top of the door. These are often seen on older trailers- even early Bambis.
I also have leaks in the bottom corners (presumably) of the front streetside window and the small (galley) curbside window. I plan to remove all interior trim around the windows and put a nice bead of Tempro around all of the window frames inside. The streetside window leak had been there forever as far as I can tell because that is where the main floor rot was when I tore things apart. I can see light (just a speck) at the bottom rear corner of the galley window. Seems a tiny hole for a leak, but it happens.
Incidentally, with the awning extended, the main door and galley window leaks are taken care of. Just gotta keep the majority of water running down the sides and not into the critical areas.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Annoying Mystery Leak rc707 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 05-28-2010 07:35 PM
Mystery Leak moosetags Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 07-08-2007 05:38 AM
Water leak mystery... TennisMan 2007 Safari SE 1 06-03-2007 06:40 PM
Mystery Leak Excellaphant 1987 - 1989 Excella 10 12-21-2005 08:57 AM
Mystery coolant leak PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 11 06-06-2005 11:34 PM
