Old 07-19-2010, 04:47 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Bambi II axle
Has anyone out there replaced the single axle on their Bambi II? Mine is original and in good shape, but I think I will need to replace all of the brake components on this trailer...it sat for 20 years...and I am just wondering if it would be cheaper in the long run to get a brand new axle with brand new brake parts or at least come out in a similar price range?
I am also worried about the "axle shearing" stories I have read as apparently 1964 axles had cast metal parts that can shear leaving your wheel flying down the roadway beside you...not under the trailer where it belongs.
If anyone has done a replacement, can you give me exact specs or the exact name of the axle you used?
PA BAMBI II is offline   Reply With Quote
Old 07-19-2010, 05:32 PM   #2
1960 24' Tradewind
Riverside , California
Yes, several, the shearing you read about is due to the very small spindle used in the Bambi and Caravel Airstreams in the early 60's. Go with a 3500# axle with the original 10" brakes, you may find you have 4 lug wheels, not available in the 10" drum anymore (only 7.5" like tent trailer use today) so you may also need wheels, 5 on 4.5" is the norm. Sorry can't mention brands as I'm affiliated with one.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 07-19-2010, 07:35 PM   #3
1964 17' Bambi II
Greg
Greg- feel free to send me a private message. Information is golden. Thanks! Ben
Old 07-19-2010, 07:41 PM   #4
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I purchased my axles from Inland RV last year and have had good results.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 07-19-2010, 07:58 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I've done about a dozen axles this year on trailers from the 60's. Everyone of them had the rubber gone hard and had no give left. They were bouncing the trailers apart. I did a 64 Bambi 11 that bounced the door off of the wardrobe getting here. Just go for a short ride in the trailer if you want proof. The cost of a new axle installed is not much more then replacing the brakes and bearings and you get the peace of mind of knowing that the wheels won't fall off.
I'll PM you the details.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-19-2010, 08:36 PM   #6
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Pa Bambi
Just replaced the axle on our 63 Bambi. Ordered a Dexter 3500# it came with brakes and bearings. Also had shock mounts added. Total cost ( PU at dealer) was $530. It came with a 5 on 4.5 lug pattern. I bought new 13X4.5 wheels. The original wheels were 13 x 4.5 4 on 4 with a small spindle hole. I could not find these any where.
Tim
Beaker63 is offline   Reply With Quote
Old 07-19-2010, 08:49 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by Beaker63 View Post
Pa Bambi
Tim
The 64 Bambi 11 came with 14"- 5 on 4.5 wheels as standard. The 63 Bambi that I have has 13" - 5 on 4.5 wheels. Who knows how many variations there are in between. They went a little bigger in 64 but they still have a small spindle that can break on a bad bump.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Bambi axle problems? lucymcdog 1997 - 2004 Bambi 4 08-17-2013 09:19 PM
Original Bambi Axle welded? C Ray Axles 12 02-29-2008 04:11 AM
2005 Bambi Axle Wild Horse 1960 - 1964 Globetrotter 1 02-02-2008 05:52 PM
1962 16' Bambi axle replacement kamo Axles 20 08-15-2006 10:57 AM
Bambi axle 61Bambi Axles 2 08-27-2005 10:16 AM
