Old 02-21-2011, 06:01 PM   #1
1964 17' Bambi II
Ventura , California
Bambi II - Awnings/Front door?
Hi, I have been restoring Bambi II - 1964 for over a year now...I have a few items that I need to get however; I do not know where to go. HELP!
  • Awning with screen
  • Front Door
  • Front Door hinges
If you could guide me on where to go - that will help...please do share.
Many thanks, Reebop
Reebop is offline   Reply With Quote
Old 02-22-2011, 11:05 AM   #2
Ottawa , ON
The front door and hinges, you might want to try a trailer "wrecker".
If you can't find one near you look up Colaws RV in Google, they are one of the largest ones around. Their website is sort of off and on; a phone call is the best way to contact them.
Old 02-22-2011, 02:19 PM   #3
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Somebody with more Bambi knowledge would have to weigh in on my suggestion, but occasionally you'll see early 60's Airstreams on Craigslist that are trashed, for cheap prices.
For example, there's a $750 '64 24 footer on the Portland, OR craigslist today that could be a good parts trailer for you, but again - only if Bambis used regular sized doors, etc.
bredlo is offline   Reply With Quote
Old 02-23-2011, 12:28 PM   #4
1964 17' Bambi II
Thank-you!
Thank-you both for your suggestions. I will check out both ideals and let you know the scoop - poop...
Have a great rest of the week! Reebop
Old 02-24-2011, 02:18 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Reebop!
When your Bambi II was new, awnings were quite unusual and screen rooms were neary unheard of. Today, ZipDee can provide you with both and they will be designed to fit your coach -- just be prepared for the cost, but you will likely be impressed by the high quality. There is also the possibility of having an old-fashioned steak-and-pole awning -- just be prepared for the setup frustrations when it comes to threading the retainer binding into the awning channel each time you wish to deploy the awning.
  • Front Door
  • Front Door hinges
Since the Bambi II was something of a one-year interim model, your door situation could require some ingenuity and creativity. Since it wasn't manufactured with a door-in-a-door setup, you may find that the reproduction hinge being offered by Vintage Trailer Supply may actually work for your door configuration. If this hinge doesn't, I am not sure what to suggest as another alternative.
If your entrance door isn't missing entirely, you might consider seeking out a long-time Airstream dealer who does body work -- the may have a craftsman who could rebuild your door. I suspect that a salvage door would likely need to be sourced from another '64 Bambi II, and that could be the proverbial needle in the haystack. You could also approach the factory service department in Ohio about repairing/remanufacturing your door.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 02-24-2011, 02:32 PM   #6
VIKING's Avatar
Boulder Creek , California
Maybe you should be looking for a '65 caravel door instead? See this link from vintageairstream.com regarding the '64 Bambi II...
64BambiII
Cheers,
Rich the Viking
VIKING is offline   Reply With Quote
Main door handle/deadbolt for Bambi II? PA BAMBI II 1964 Bambi II 1 02-28-2011 09:43 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
Mystery Door Leak - Help Needed MDSilverado Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 02-14-2011 01:11 PM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
RM 2410 and 2510 Freezer Door Widths pbearsailor Refrigerators 4 01-07-2011 07:16 PM
