Originally Posted by Jayjj1974
Just bought a Bambi II and have been inspecting the whole tailer. I noticed the shocks look original and should probably be replaced. Anyone know what might be a good modern replacement part?
You can use the current shock that Airstream has been using since late
1968.
But, you might have to shorten the vertical bracket so that the distance between the studs is no more than 14 1/2 inches.
However, that dimension should only be used when using a "known" good axle.
That dimension will be a lot less if the axle rubber rods are history, which happens after about 25 years, and a lot sooner if the trailer was parked and not moved for a couple of years.
