I used a belt sander to level out all those rough spots. Went around looking for possible soft spots...treated any suspect with Git-Rot from West Marine, filled low areas with leveling compound then belt sanded lightly again. Then I used a high quality underlayment. Ued Pergo flooring like many others here.
FYI....Home Depot puts out all reduced price items ...like opened pkgs, returned items and (the one I like best) unclaimed special orders, in the A.M.
A quick check early saved me nearly 60% on my Pergo. It took a full three boxes to do the 66 Caravel...with one board left over. Have fun.
Edit......Remember...the Pergo raises the floor level. I had to cut out the freshly laid Pergo under the water tank because the filler spout no longer aligned. Everything else was manageable.
We had a similar experience with the floor in our Caravel, and we used sealer/adhesive remover to pull up the black stuff. It worked great - softened everything up so that it could be easily scraped with a putty knife.
Mel
1960 Caravel "Boris"
1967 Safari "Sparky" My Photos
... I would like to see more pictures of the interior of you trailer, if you have the time.
Don
Here are three photos of the interior as we found it when we picked up the trailer. I will post resto photos later on this summer once we finish the floor and finish putting the interior back to together.
Thanks for the pictures. Our Bambi and your Bambi II are similiar, however the extra length puts your kitchen on the stree side ours is in the back. What exactly is the layour of the back of your trailer.
Don
Thanks for the pictures. Our Bambi and your Bambi II are similiar, however the extra length puts your kitchen on the stree side ours is in the back. What exactly is the layour of the back of your trailer? Don
Don:
R.J. Dial's web site is a wonderful resource for trailer peeking:
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
Don
Post #3 above has a photo of the back of the interior. Directly in the center of the rear is a bathroom sink with the furnace underneath. On the streetside is the wet bathroom; on the curbside is a closet.
We are trying hard to finish as much of the Bambi II restoration prior to our upcoming Region One rally where we will be showing it off during the vintage open house. I spent a good 20 hours this past weekend sewing curtains and will be dreaming about pinch pleated drapes for awhile! Hubby finished the plumbing repairs/renovation while I was busy sewing so we now can pump water, draw water (hot and cold), shower, etc.
The floor is almost ready for its final application of Marmoleum. I leveled and patched the floor this week using a portland cement based compound.
In the far right corner (in the shower stall) is a portable A/C unit which has been working hard all week to keep the humidity level low in preparation for laying the Marmoleum. I'm also acclimating the tile to the "environment" as recommended by the manufacturer.
How do you light the water heater with original cover on? I assume its a self lighting heater?
I used plumbers tape on my cover (I'm trying to keep the original too) I don't think its a long term solution - do you know how hot it gets? I was thinking about using some rubber weatherseal with that sticky backing if it doesn't get too hot....
