Old 10-03-2014, 04:26 PM   #1
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Wires/Power for stove vent & roof vent.
My stove vent motor was seized up, so I took the old roof vent motor and swapped fans. Then I discovered the wires to the stove vent produce no power (I tested with a light bulb). On a hunch I tried my mint newly installed Fantastic Fan (the trailer is being restored, when I took it in to the installer, I had no battery in the trailer), the roof fan doesn't work either. I figure they both share wiring. In the street side closet are wires to the reading lamps over the street couch, which I've been working on (the ball socket came undone, I managed to fix it) and I think these two sets of wires from the hole next to the electric box in the closet may/may-not be related to my vent power problem.
Question; where do the stove vent power wires go when they disappear into the curb-side ceiling? WHere do I look for the other ends of them?
Jeepers! is offline   Reply With Quote
Old 10-03-2014, 06:00 PM   #2
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
All 12 volt systems work (pump, Fantastic Fan, lights), except for the stove exhaust fan. I pulled it out and tested directly to battery, works. Lightbulb applied to stove vent wires does not light. Arg! Darn stove vent!
It could always be worse.
Old 10-03-2014, 08:48 PM   #3
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
Check for fuses by your battery charger
Rolland is offline   Reply With Quote
Old 10-03-2014, 09:21 PM   #4
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
I just went out to check those fuses. They tested fine. But on a hunch I pulled the newly installed Fantastic Fan frame off. Yep, that was it. The installer at the Airstream Dealer, when he put in the Fantastic Fan, simply taped off the "extra" wires and tucked them behind the FF frame. Dork
Thanks!!
Roof Horns: where are the wires shepherd57 Classic Motorhomes 11 07-09-2013 11:09 PM
Feed wires for Satellite roof mount lsinclair Computers, Internet & Satellite 3 05-04-2008 10:48 AM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Testing the Stove Power Vent RobertC Stoves, Ovens & Microwaves 4 08-03-2006 10:21 AM
