Old 03-10-2014, 10:14 PM   #1
1965 17' Caravel
SAN LUIS OBISPO , California
Water heater replacement
ANYONE REPLACED THE ORIGINAL PROPANE WATER HEATER IN THEIR 65 CARAVEL ?
MINE HAS A SLOOWW WATER LEAK, PLUS IT HAS ALWAYS BEEN DIFFICULT TO LIGHT - SO PERHAPS NOW IT THE TIME NOW TO REPLACE IT...ANY MAKE/MODEL ADVICE THAT WILL FIT IN THE ORIGINAL LOCATION WOULD BE GREATLY APPRECIATED !
THANK YOU !
Doug
San Luis Obispo, CA
SSTANK05 is offline   Reply With Quote
Old 03-13-2014, 09:34 AM   #2
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
The direct replacement would be the Atwood 6 gallon. Atwood bought out Bowen (the original brand) and their current model fits almost perfectly in the hole (may have to trim 1/4" off the top of the hole?). You will receive a white hinged door though. It can be painted silver and you may be able to order a stainless steel door, I am not sure. I chose to drill out the original cover and reinstall the original, so it looks like nothing has changed. All new 6 gallon gas only model inside, but nobody can see the difference outside. Here is your best source and they explain the different models well…
Atwood 6 Gallon
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 03-13-2014, 10:24 AM   #3
1974 Argosy 20
Kooskia , Idaho
If you have a Bowen now the Atwood will be a direct replacement, as noted by Jewel65. The only other thing is that the new Atwood heaters have a slightly different gas input location, and either a new hole will need to be bored in the new heater and the old one plugged and the inlet pipe fitting turned, or your gas line will need to be re routed (and replaced) to fit the location on the new water heater.
Old 03-13-2014, 10:35 AM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I put a note in the "Plumbing - Water Heaters" board about one on sale. You might check that out.
'73 Original water heater - keep or chuck? Jamiep Water Heaters, Filters & Pumps 2 12-16-2011 01:48 PM
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
'08 Safari water heater only staying lit for 3 mins... bonginator Water Heaters, Filters & Pumps 3 08-21-2011 07:51 PM
Tankless Water Heater lucymcdog Water Heaters, Filters & Pumps 4 07-04-2011 05:00 PM
