Old 05-16-2013, 10:11 AM   #1
funhouse's Avatar
2018 23' International
1965 17' Caravel
La La Land , Wisconsin
Replacing the Refrigerator and scoop
Has anyone replaced their refrigerator without rebuilding the entire cabinet? I'd like to find something that would fit without losing the drawer above it. I wondered about the Dometic RM2354. Also, does anyone know if the refrigerator scoop sold at Inland RV fits the Caravel (fiberglass piece that vents the fridge). Is there anywhere else that sells them? Thanks for all the help this forum gives us!
funhouse is offline   Reply With Quote
Old 05-16-2013, 04:14 PM   #2
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I think I remember reading from somebody that has used the fiberglass fridge vent that it works, but maybe needs some modification. I don't think it is made specific to the caravel, but maybe generally made to fit more than one model airstream. Maybe you will hear from somebody who has actually tried one. I don't know of any RV fridge that will fit that space, except the original 60's model. If you can find or have the original, it can probably be fixed to working condition. That's the approach I am taking. The old original units will run forever.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 05-17-2013, 08:18 AM   #3
funhouse's Avatar
1965 17' Caravel
Thanks Jewel, we have tried to start up the fridge, but it wouldn't light. So we used the old standby ice chest. The fridge looks OK, so we'll try to fix that. The scoop has cracks all along the riveted edges. Is it possible to repair it? The list just goes on and on.........
Old 05-17-2013, 10:58 AM   #4
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
If the fridge won't light but is otherwise okay, take the burner apart and use some carb cleaner on it then blow it out with compressed air. There is probably small particles in the burner. That is a very small hole that can get plugged up. Clean out the soot in the flew above the burner with the wire brush that is already there. Put the burner back together and reinstall. It should light as good as new. Mine is currently out of the unit and easy to get to. It may be more difficult if it is still in the unit, but I think it is possible. It will save you about $800 to get your old one to work!
I think you can repair the the edges of the scoop with fiberglass mat and resin. Or, I have seen some line the edge with aluminum strips and rivet the strips on over the edge.
Old 05-18-2013, 03:37 AM   #5
1965 17' Caravel
Lexington , South Carolina
My fiberglass was cracked pretty bad too. I was going to buy a new one, but then I saw some pictures of one on line and it didn't follow the contour of the wall very well. I ended up using fiberglass and repaired my old one. I'm glad I did!
Maximus is offline   Reply With Quote
Old 05-18-2013, 09:24 AM   #6
funhouse's Avatar
1965 17' Caravel
Thanks for the information! I was afraid it wouldn't line up right.
Old 06-14-2014, 11:07 AM   #7
hamiltonmj's Avatar
2013 Interstate Coach
Opelika , Alabama
I saw two Caravels with the bigger dometic refrigerator on Fred's Airstream site for two 65 Caravels. I am thinking of using the 2454 with gas, electric, and DC.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
Old 06-14-2014, 05:52 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most ads for refers give the dimensions. They also list the cubic foot capacity of the refer.
TG Twinkie is online now   Reply With Quote
Old 06-14-2014, 07:12 PM   #9
1974 Argosy 20
Kooskia , Idaho
You might look at the Dometic 2410 and 2510 refrigerators. They are simple refrigerators with the old stile 2 level flame and do not use any 12 volt power for anything except initial lighting (12 volt spark only, after that, gas is used) They are two way, propane and 120 volt. No circuit boards, no electronics. Great little refrigerators.
