Old 09-10-2008, 07:40 AM   #1
65CV's Avatar
Western , Massachusetts
Renovation of gutted 1965 Caravel
I guess we have a little catching up to do.
We bought a gutted Caravel late last year with the intent of a renovation much like the original design. We never would have considered renovating the trailer without the information on and the support of this forum. Welcome to the Frontpage - The Vintage Airstream Podcast has also been invaluable and thoroughly enjoyable entertainment. (Yes, Frank, we have donated and will again.) We plan to document our progress – and we know you love pictures.
I’ll try to remember to add links to threads that were especially helpful, starting with the major renovations in this link: http://www.airforums.com/forums/f44/...ons-35399.html
So far, we have gutted the PO’s modifications, removed all the interior panels, insulated the upper half, popped the top, replaced some c-channel, cut and welded frame members to make room for grey tanks, installed the belly pan corners (ugh!), dropped the top, bucked it and nearly finished a panel replacement.
We did quite a bit of the heavy lifting – literally – while my son was home this summer. Now that he’s no longer available, I will step back and document things. I’ll try to pull the pictures and story together over the next weeks as we try to get the “aluminum tent” ready for a shakedown cruise in mid-October.
Here are the first two pictures: as-found and today. It doesn’t look that different, but the floor is now rock solid, the shell has only one pesky little leak and the interior is nearly ready for a rebuild.
ID:	67177   Click image for larger version
65CV is offline   Reply With Quote
Old 09-10-2008, 07:44 AM   #2
65CV's Avatar
As found interior
Here’s the interior as-found.
All the parts that were gutted from the original trailer were available, but were stored outdoors. We took everything for patterns, but the plywood was so delaminated that it was unusable. We’ll reuse some of the original mahogany. The PO replaced the axle with a Henschen from Inland and replaced the plywood floor, so it towed home like a dream.
Old 09-10-2008, 07:59 AM   #3
65CV's Avatar
Leaks Everywhere
We were debating about removing the interior skins. The PO had cut all the wires at the grommets and riveted new conduit on the walls. I’d hate to put this much work into the trailer and have that look.
Then the first good rain hit.
I’ve heard Rob from the VAP say that “they all leak”. I didn’t believe the PO when he said it didn’t, but I didn’t expect a flood! The first big rainstorm resulted in water everywhere. That was the last straw for the interior panels.
We gutted all the changes made by the PO to the interior and removed all the panels, wiring and insulation.
There were 17 separate leaks! The tops of the windows were the worst, especially fore and aft. The new fantastic fan leaked like a sieve. The Caravel logo was one of the worst spots, shown in the picture below. The four corners of the trailer – the vertical seams where the round ends stop and the flat walls begin were also bad spots. It looks like pop rivets were used to hold the domes in place before they were bucked. These raise areas also leaked badly.
There were plenty of trails left behind as show in this picture of the back of the Caravel logo.
Old 09-10-2008, 08:04 AM   #4
65CV's Avatar
No more internal panels
Here are some pictures of the interior that give a good idea of the end and side internal structure.
I have a lot more. If anyone wants high resolution copies emailed, PM me. There will be more pictures of internal ribbing when I document the insulation.
ID:	67181   Click image for larger version
Old 09-10-2008, 09:21 AM   #5
2333's Avatar
1962 24' Tradewind
Rabat , Morocco
So far the trailer looks like a great candidate for what your doing. I too was surprised at the leaks and issues you find when you remove the inner panels. Corrosion, bad rivets, etc. That was the right move. You won't regret it later when you're sleeping soundly during a rain storm and not worrying about leaks.
Craig
2333 is offline   Reply With Quote
Old 09-10-2008, 01:34 PM   #6
65CV's Avatar
Leaks
Craig-
You're right. Actually, it was pretty cool being in the trailer as Hanna passed over. It was great to see dry spots almost everywhere.
We used quite a bit of vulkem on the outside and, with the skins off, sealed the seams with Alcoa Gutter Seal. Definitely paid off.
John
Old 09-10-2008, 02:41 PM   #7
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
John,
What areas did you use Vulkum vs Gutter Seal?
J
1956Safari is offline   Reply With Quote
Old 09-10-2008, 04:30 PM   #8
65CV's Avatar
Vulkem vs. Gutter Seal
1956Safari-
I used Vulkem on all external seams and Gutter Seal on all the internal ones. I had heard somwhere that gutter seal flows well into the seams. The Vulkem went on well on the external seams using plastic syringes that I picked up at West Marine.
After doing the internal seams, I heard on the Vap that GSM uses Automotive Seam Sealer on the internal seals. It's another good alternative.
John
Old 09-21-2008, 07:47 PM   #9
1965 17' Caravel
Birmingham , Alabama
Wow John, you've done some great work! I'm sure its a relif to see it all going back together again. We missed Hanna but had a long visit with Tropical Storrm Faye. The Caravel didn't leak but our house did! Keep up the good work and keep us informed!
gwchitty is offline   Reply With Quote
Old 09-23-2008, 04:21 PM   #10
65CV's Avatar
House leaks
cosmos-
Keep after the house leaks! We just finished some repairs to a decades-old water leak. You can do a lot to an airstream (or two) for what it cost!
I'll keep posting when I can. We're scrambling to get the aluminum tent ready for a leaf peeking trip.
John
Old 09-23-2008, 04:23 PM   #11
65CV's Avatar
Insulation Choice
The next step was to insulate the walls. Easy until you start reading the threads on this forum -- so many options.
The best two threads I found on insulation choices are by Zeppelinium and Malconium. Links are below.
At the risk of oversimplifying a lot of very good work by two bright guys, I viewed the Zep tests as measuring how warm my trailer would stay in the winter while the Malconium tests measured how cool it would stay in the summer. [note: Zep says that there is more radiant heat testing to come].
Our camping definitely leaned towards "cooler in the summer", so we chose Malconium's bubble foil method.
There is so much information in this forum and sometimes it's hard to find. Some of the better information on insulation is in a thread called "Painting your Airstream red". Who woulda thunk?
In the first thread, note especially posts #59 and #82
http://www.airforums.com/forums/f474...red-13363.html
http://www.airforums.com/forums/f46/...cks-30196.html
http://www.airforums.com/forums/f46/...sts-40442.html
Old 09-23-2008, 04:27 PM   #12
65CV's Avatar
Insulating the top half
We only insulated the top half in preparation for redoing the frame-off.
Here is what the top half looked like. Some wires go underneath the insulation -- wires that need to be accessed later were run on top.
This was back in March. It made an incredible difference in comfort!
We tried two different adhesives: Loctite and PL. The difference was night and day. In cold weather, the Locktite wouldn't cure. The PL was terrific.
For a 17' Caravel, it takes about 3 1/2 rolls of Reflectix and about 10 tubes of PL adhesive.
ID:	68063   Click image for larger version
Old 09-23-2008, 04:39 PM   #13
65CV's Avatar
Hanging Cabinets
Before putting the interior panels on, we added extra support to the overhead cabinets. One of the pictures provided by the PO was a 4x4 supporting the cabinet -- that wasn't happening again.
We set up to thru-bolt the cabinets by making an angled washer then gluing it and a nut inside the strong channel. We'll make a slot in the cabinets so that they can expand and ride on a set of 1/4-20 stainless bolts. That will hold them!
Here are the pix on the floor and installed. The blue tubing behind the installed bolt is plastic conduit with a messenger line installed for future wiring across the top of the trailer.
ID:	68065   Click image for larger version
Old 09-23-2008, 04:42 PM   #14
65CV's Avatar
Shell Off
After we finished the rough wiring and the insulation of the upper half, we reinstalled the interior upper panels. Then it was time to pop the top.
Given the warnings in the frame-off threads, we used so much wood to stabilize the shell that it weighed a ton! It was worth it -- it is really an eggshell.
Here it is in the backyard. Stuff is spread everywhere. The grass is just starting to recover 2 months later.
1965, 1965 caravel, caravel
A/C for a 1965 Caravel toastie Furnaces, Heaters, Fireplaces & Air Conditioning 10 07-14-2019 01:30 PM
Almost done with our 1965 Caravel toastie Member Introductions 31 12-30-2007 05:37 PM
Newbie w 1965 Caravel Amfrench Member Introductions 5 08-12-2007 05:00 PM
1965 Caravel toastie Plumbing - Systems & Fixtures 1 12-31-2005 03:27 PM
1965 Caravel sunnyhillfarm 1965 Caravel 4 01-28-2004 07:39 AM
