Old 05-04-2010, 04:47 PM   #1
GJP
1965 17' Caravel
Wichita , Kansas
Putting the '65 Caravel back together
I am getting ready to re- zolatone our gutted 65 Caravel. After pulling the belly pan, and fixing the obligatory floor sections ( which was fairly minor- surprisingly), and one rusted outrigger & cross member, I am ready to start prepping for a new zolatone interior. I purchase a new 45amp converter and fuse box from the great folks at Vintage Trailer Supply, and would like to understand how it all hooks up before I start disconnecting the old. I have the same set up as Toastie posted pics of some time ago showing how things hook up at the converter side, so I get that. I dont understand how to hook things up at the fuse box side- all the light/receptacle wiring coming out of the skin that go into the old fuse box- the one w/ the toggle switches for city/battery power, etc. Anyone have pics showing how all this hooks up to a new fuse box? I plan on having an electrician check me out, but would like to understand it better before I disconnect all that.
GJP is offline   Reply With Quote
Old 05-06-2010, 02:36 AM   #2
65CV's Avatar
Western , Massachusetts
Original Manual
GJP-
Congrats on getting to the stage where you're rebuilding!
Would the original manual help? Chapter 11 has the original wiring diagrams. I don't think it's online anymore, but if you pm me, I'll email you a copy.
John
65CV is offline   Reply With Quote
Old 05-06-2010, 05:16 PM   #3
GJP
1965 17' Caravel
Wichita , Kansas
Thanks John! I have copy of that, just not smart enough to figure out how it works. I want to go from what I have (on the left side of pic) to the 12V fuse panel on the right. Thought someone surely has made this exact change over
Name:	old to new.jpg
Old 05-06-2010, 08:21 PM   #4
R n B
King O D Road's Avatar
1965 17' Caravel
1961 24' Tradewind
Ephrata , Washington
Just went through that with our 65 caravel. In my case I had the street-side outer panel off of the trailer so it made it easier to do the wiring changes. I took each wire and used a VOM and did a continuity check on each wire and labeled it on both ends 110V and 12VDC. PM me if you want more information as to what I did. Roger
King O D Road is offline   Reply With Quote
Old 05-06-2010, 08:31 PM   #5
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I've been watching this and waiting for Andy to chime in on this. I did the exact inverter replacment. I have not made any changes to the Univolt. But, I can't see how the inverter could charge the battery. The only time it's charged is when it's hooked to the tow. I didn't see a need to tear out the univolt, but it would be nice to have the battery maintained when your pluged in to 110 power.
Bigventure is offline   Reply With Quote
caravel
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 04:11 PM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
Putting a 23 Safari back on the road Bejasus Wheels, Hubs & Bearings 5 06-28-2011 02:09 AM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
