Old 08-26-2014, 06:13 PM   #1
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Plastic Cabinet Clips
Am I going to have to remove the cabinet door trip piece that the clips are riveted to to replace the clips? It seems so, as I can't drill out the rivet stump.
Jeepers! is offline   Reply With Quote
Old 08-27-2014, 08:21 AM   #2
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Mine were broken, but I didn't try to replace them with a new set that would also break over time. I used these instead. Much better product than the original plastic clips.
Dual Roller Catch
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 08-27-2014, 01:52 PM   #3
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
I already have the replacements. I'm going with them (if I can solve this issue) until we do the shell-off restoration in a few years.
Old 09-02-2014, 10:02 AM   #4
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
I removed the cabinet doors. I need to reglue the coverings also. But I'm stuck, how to remove the rivets stumps in the doors. Any suggestions? Bueller? Bueller?
Old 10-02-2014, 05:42 PM   #5
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Clips continued.
As it turned out the rivets, that held the broken clips to the edge of the door, could have the center punched through and the rest of the rivet pulled out by a bent paper clip - on most of the doors. It was hit or miss. Out of six doors, half this trick worked on. The other three, I was able to push the drilled off rivet further down into the hole. All of the doors got a drop or two of white glue into the rivet hole and let dry, I then used a plain ol little wood screw in the hole for the new clips. The important thing I came away with was I had to use the screws (I intended on re-riveting) however the rivet tool tip was too big get near the hole, the clip would be broken off if I forced it. The screws worked better anyway, looked better as they were beveled and fit nice and flush.
Old 10-03-2014, 09:18 AM   #6
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Glad you got it solved. I have had to use small washers stacked on top of each other to build up space for some hard to get too locations with my rivet gun. The curtain tracks was one of those. I had to build up washers in the track until my rivet gun fit onto the top washer, because the rivet gun tip wouldn't fit in the track slot. It worked, but it took some trial and error to get the right size washers. I thought about using screws also, but I wanted to use rivets and that is the only way I could make them work.
Plastic medicine cabinet latches willbrackman General Interior Topics 6 05-08-2017 08:07 AM
Plastic mini-blind clips Snaken49 2009-2015 Flying Cloud 0 03-14-2013 03:44 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Rubber or plastic piping on cabinet edges? durans54 Cabinets, Counter Tops & Furnishings 12 03-28-2007 09:07 PM
Plastic cabinet end cap wcdelorme Cabinets, Counter Tops & Furnishings 0 05-11-2003 10:12 AM
