Old 12-22-2015, 09:43 AM   #1
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Magic Chef 160 Parts
While working the pilot light/thermostat/igniter I broke the pilot threaded nipple off the assembly. I was fixing/shortening the darn broken aluminum tube and salvaging the tiny brass compression ring and overtightened the connector when the threaded part of the iron pilot/thermostat/igniter broke off.
A Google for "Magic Chef 160" doesn't really reveal anything.
Where do I find one of these?
Jeepers! is offline   Reply With Quote
Old 12-22-2015, 10:40 AM   #2
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
I have the same problem...could use the entire assembly. Here is a photo of what's needed. Hope someone has suggestions...I've tried everywhere.
Name:	pilot light fittings.jpg
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 12-22-2015, 11:18 AM   #3
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
Most RV sales have them. Check Camper's World. I had to replace one and it wasn't that expensive .
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 01-05-2016, 10:59 AM   #4
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
O.k. I found that tiny aluminum tubing on ebay for $15, and a typical plain standing pilot light assembly too. I removed the original pilot burner from the old 2-stage assembly and drilled out and tapped the burner's hole for a screw. I then took the new standing pilot assembly and removed the thermocouple and cut the excessive bracket off and mounted the new pilot to the old 2-stage pilot assembly with the screw. I then took the female compression fitting from the new aluminum tubing and cut off the male fitting from the new pilot tubing and replaced it with the female compression fitting. Viola, a new pilot light mounted to the old 2-stage combo pilot assembly and it works!
Old 01-05-2016, 11:16 AM   #5
Gilmurr's Avatar
What did you use as search words on ebay to find the tubing?
David & Andrea
Old 01-05-2016, 10:12 PM   #6
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
It wasn't ebay!
I lied! It was Amazon, I goofed.
1/8 Pilot Light Tubing
Sold by: InnovativeSupply
$10.21
Old 01-06-2016, 04:18 PM   #7
Gilmurr's Avatar
Thanks..got it..now hope it fits ok....will have to wait until May as trailer is in storage
David & Andrea
Old 01-06-2016, 08:27 PM   #8
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
As it turned out, I only used the compression fitting, and the tubing remains in the bag.
Magic Chef needs magic fix Sheridan Stoves, Ovens & Microwaves 8 11-21-2009 03:44 PM
Magic Chef parts, free. Dugger10 Stoves, Ovens & Microwaves 2 04-11-2007 11:21 PM
Magic Chef parts free... MotorSeven Stoves, Ovens & Microwaves 2 02-11-2007 07:57 PM
Parts for OLD!! Magic Chef Refrigerator BB 55 Bubble Refrigerators 15 10-25-2006 11:10 PM
parts for Magic Chef range aeriqua Stoves, Ovens & Microwaves 1 01-09-2006 06:26 AM
