Old 08-26-2016, 01:30 PM   #1
1965 17' Caravel
Alliance , Ohio
Insulation
Going to remove and replace belly pan. What type of insulation do I replace the existing with?
LarryandJodi is offline   Reply With Quote
Old 08-26-2016, 01:55 PM   #2
1977 31' Sovereign
2005 30' Safari
1977 28' Argosy 28
North Port , Florida
when we did ours we went back with 2" foam board insulation.
cliffcharb is offline   Reply With Quote
Old 08-26-2016, 02:22 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Really whatever you want. I used rockwool since it repels water and is easy to work with. 1/3 sheet laid on top of a full sheet was the right thickness.
Why are you removing and replacing your belly pan?
TheGreatleys is offline   Reply With Quote
Old 08-26-2016, 03:34 PM   #4
1979 23' Safari
Wayland , New York
Foam board insulation. You can get a couple inches under there easily. Doesn't hold water. Foam board adhesive backed up by some screws 1/2" longer than the board thickness. Cut some scrap aluminum into little squares to act as washers for the screws.
Old 08-26-2016, 05:05 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you use foam board, you can use canned foam to seal and glue it
Old 08-26-2016, 05:16 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Good advice why put more stuff in there that will soak up water and make a great nest for critters?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-27-2016, 06:03 AM   #7
1965 17' Caravel
Alliance , Ohio
We are removing the belly pan because the aluminum is deteriorating where it attaches to the metal underside.
Old 08-27-2016, 07:44 AM   #8
1974 27' Overlander
I see. Be prepared to open Pandora's box. Deteriorating aluminum often hides deteriorating frame members.
Old 08-27-2016, 08:00 AM   #9
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I used no insulation on the underside of mine. There is nothing under there that can trap moisture and I am putting a hinged, aluminum louvered vent centered between each crossmember. Just to keep a bit of airflow in the belly.
Plus be able to open it up and use a snake cam to inspect.
Dingo Girl is offline   Reply With Quote
Old 08-27-2016, 08:30 AM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
In other words "Ignorance Is Bliss".
Old 08-27-2016, 09:22 AM   #11
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We did not insulate under the floor either. Instead, we added a floating cork floor to the trailer. Floor is much warmer now, and nothing under the trailer to soak up water or attract critters.
Kay
Old 08-27-2016, 10:50 AM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Those that chose no insulation:
Do you camp in cold weather?
Did you protect your tanks from freezing?
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 08-28-2016, 06:31 AM   #13
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
My tanks are inside the trailer on the floor.
I don't plan on camping in any weather below 40 degrees.
I've been shopping for flooring recently and wonder if my furnishings, gaucho, closets etc would shift during travel if they are only attached to the walls?
Old 08-28-2016, 07:16 AM   #14
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I don't think that the insulation that was put there by the factory was doing much to begin with, partly because of the way that it was installed (compressed in many areas), and mostly because of what becomes of it after a short amount of time. (chewed, soaked, sagged, etc).
I used my camper for several years after I first bought it, then decided that the rear floor needed some help. I decided to patch instead of replace, and in that process, I removed a bunch from the back half of the trailer. Never noticed any difference inside, during cool-weather camping.
eventually, I had to completely replace the rear floor, and that has turned into a full monty, added grey tanks, bigger black tank below the floor.
There are 9 2-foot frame bays in this camper, and 5 of them are full of "tank". no room for any insulation. Even if I were to attempt something in the other half that aren't stuffed full of tank, I don't think it is going to make any measurable difference.
waste water isn't going to freeze solid the moment the outside air temp hits 32; it would have to get below that and stay below that for a long time. Around here, the "last hurrah" of the season is typically Columbus day. It might dip below freezing overnight for a short time up north, but thats about it. I really don't think its necessary, unless you are a hard-core winter camper, or a full-timer in the north. Just not practical when the walls (through which probably 90+% of the heat escapes) are only 1 1/2" thick.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Insulation- Prodex or Foam Insulation Board? Danny Z General Interior Topics 7 08-26-2015 08:21 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
is the insulation flammable ? oldvws General Interior Topics 3 12-31-2002 11:12 AM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
