Old 05-21-2018, 06:56 PM   #1
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
I'm back!
So.........its been years of absence as I have been away from the Silver Belle community......but I have never lost my love for the Airstream.
I have even visited the life of SOBs but after many years I am back with a vengeance and have a REAL project.....a 1965 Caravel....no AC, and practically needs a total refit.
But I am no stranger to the remodels of Airstreams and am already in with both feet....
I have already removed much of the interior but am looking for a way to avoid replacing the entire wet-bath shell as it has spider cracks in the floor from stress and some floor rot underneath.
I can get to the rot from the belly pan but seriously do not want to deal with removing the entire interior end shell. I am considering covering the shower or basin with a liquid sealant like flex seal or something of that nature. I have refinished bathrooms in Airstreams with epoxy paints, but they were not actual basins that had a lot of water on them. Does anyone have experience or suggestions for this?
Thanks and I look forward to sharing with the ol Airforums brethren!
I guess I will change my avatar as I have long sold the ol 36 Classic...sigh...I miss the ol girl
smily is offline   Reply With Quote
Old 05-21-2018, 06:59 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome back! Please keep us posted on your progress on the new project.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 05-21-2018, 07:12 PM   #3
Kevin245's Avatar
Welcome back!
You can check out anytime you like. But you can never leave...
Eleanor Roosevelt
Old 05-21-2018, 09:00 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello from Colorado: Nice to meet you for the first time. I hope to follow along in your Caravel renovation project.
I don't know if you plan a "restoration" to factory built standards or a renovation where you upgrade your trailer to your liking. Quite frankly, not everything done in 1965 was the greatest. I'm a renovation guy.
I never developed a liking for a wet bath. My son has one in his 69 Globetrotter. He doesn't have a gray tank, so a shower seems a bit out of the question.
So what if the fiberglass corner piece was removed for good, and you built a "water closet" instead. Newer Airstreams have a vanity sink outside the bathroom kinda like some hotels do. Maybe a guy could get along with just the galley sink since the trailer is small. That might provide room for something else. Airstream was keen on these fiberglass parts in the 60s, but my 75 Overlander doesn't have any fiberglass parts.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 05-21-2018, 09:11 PM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome back, Ken!
Old 05-27-2018, 02:10 PM   #6
Still Working
smily's Avatar
1994 36' Classic 36
wet bath exit
well.....I have always heard and professed that "everything that is in an Airstream came in the door and will go out through the door......"
Guess what will not go out the door?
After all of the gut job, I finally get the wet bath to release itself from 53 years of confinement.....and it will not fit through the door...
any recommendations before I get the sawzall out and pick the best line for a bisection?
Old 05-27-2018, 02:37 PM   #7
1989 34.5' Airstream 345
Ebro , Fla Panhandle
If I ever have my shower insert out, I'll do a lot of epoxy fiberglass reinforcement on the reverse side. Try to firm up the flex of the floor. Then a little filler in the hairline cracks and LP paint.
Are there any Windows that are larger than the door?
Good luck with getting your new stream sorted!
Cheers Richard
tevake is offline   Reply With Quote
Old 05-27-2018, 03:00 PM   #8
Still Working
smily's Avatar
1994 36' Classic 36
windows
Already thought if that and unfortunately.....no the windows are no that large...I am looking for a line to cut and place the two pieces with an abutment extrusion and caulk....just seems the easy way to go...and agree that some reinforcement is in order
Old 05-27-2018, 09:28 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I believe Airstream got it in the door at the factory. The door and screen may not have been mounted yet. Airstream has no other way to assembly their trailers since they mount the body, do the plumbing and wiring, check for leaks, then interior skins and finally the furniture. It's gotta go through the door.
Maybe you will wake up in the middle of the night with a vision of the right orientation to get that big piece out the door.
Maybe your Airstream dealer, or a call to Jackson Center for technical help would help you.
David
WBCCI #8607
VAC Region 11
Old 05-27-2018, 11:01 PM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Welcome back. Glad to hear that you now have a 65 Caravel. Caravels are one of my favorite Airstream models.
Regarding your wet bath module, I would hold off on the sawzall. Once you go there, you cant go back. Give some time for some other Caravel owners to chime in.
Dan
TouringDan is online now   Reply With Quote
Old 05-28-2018, 04:48 PM   #11
Still Working
smily's Avatar
1994 36' Classic 36
Im doubtful
Ive done a bunch of interweb research and the consensus is........the wet bath does not fit through the door......
what a three day weekend....I have gutted the Caravel....removed the entire from interior skin, cut out the floor and headed to a shell on restore...drilled about 300 rivets this weekend...
and in the meantime...looking how to restore my black tank...yep cracked up and needs new fittings....Im think of all kinds of alternatives to buying 300 worth of aftermarket workarounds...if Im going to do fabrication, you can believe it will be in a rejuvenate nature....
any pointers on the black tank restore? thinking fiberglass wraparound...or cut out the top and build a new one out of aluminum or something that will bare the weight of the toilet and the occupant....
Old 05-28-2018, 08:43 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Some folks here have fabricated their own holding tank from ABS sheet. It can be done, easier if it is a box tank. Most black tanks are just that, and not designed to hold any weight.
I purchased a replacement tank. And your point about the dollars is correct. But I don't have the skills to fabricate one of my own that would fit and have a good slope on it.
Here is a photo of the new store bought above floor black tank for the 69 Globetrotter. It fits under the fiberglass console and plywood support in the wet bath.
David
Name:	1703 Toilet Set (Small).JPG
ID:	312308   Click image for larger version
Name:	1703 Black Tank Top View (Small).JPG
WBCCI #8607
VAC Region 11
Old 05-30-2018, 02:23 PM   #13
Still Working
smily's Avatar
1994 36' Classic 36
good thing out of stock
I actually contemplated ordering the tank from VTS....good thing they were out of stock....I did not know how easy ABS is to work with... (thank you Youtube) I have some sheet ABS ordered up, a fitting or three and a complete Valterra setup...I think I will have a complete tank with fittings for under a hundred bucks....
I'm working with the shell and cutting out the flange and the fittings.....yes im taking photos and will load them all when completed...
Oh....and did anyone know that Lowes is selling RV products on the shelf?? check the plumbing section for ALOT of RV products including electrical stuff..yes in the plumbing section..
Old 06-03-2018, 05:47 PM   #14
Still Working
smily's Avatar
1994 36' Classic 36
refrig and stove vent covers wanted
Anyone have ALUMINUM refrig and stove vent covers for sale>
know a source?
2017 AI back huge back TV obstructs walkway Perpich Audio, Video & TV 0 10-07-2016 12:48 PM
Back and forth, back and forth.....what 2 do??? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 19 11-30-2009 06:24 PM
Odd back-to-back eBay auctions .... summerkid Trailer Values 5 09-12-2005 01:34 PM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 03:49 AM
Get back to where you once belonged* 83Excella Forum Admin, News and Member Account Info 3 07-01-2002 11:06 PM
