Old 01-06-2016, 01:29 PM   #15
Watertown , Massachusetts
Tiny oven
Ha! I use my tiny oven to store my toaster.
Seriously, I did use it once, but it seemed to be more trouble than it was worth. I've considered using the broiler, but then I'd have to clean it and an outside grill is easier.
sallye is offline   Reply With Quote
Old 01-06-2016, 01:50 PM   #16
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I need to get some of those tiles for our oven as it get used on most every trip. I suppose a big box store carries these?
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-06-2016, 02:09 PM   #17
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
A "pizza stone" in a fancy kitchen store will cost $35 to $50.
An unglazed tile in your local hardware store - $4
It should be noted that this is a good idea in a gas or electric oven, not in a convection microwave!
Your oven will never know the difference. Another Alton Brown "Good Eats" tip. I also liked his ceramic smoker made from a big terra cotta pot.
Paula
Old 01-06-2016, 03:08 PM   #18
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
All good tips...the temp gauge is a must! un-glazed tiles do certainly help with even heat and can also be gotten for next to nothing at a garden or stone dealer, they may even give you some. Another is I put a sheet of aluminum foil on the bottom of the oven immediately when purchased to catch any possible spills. I hate cleaning ovens, so I make sure horizontal flat surfaces are covered. I love to bake so an oven is a must. We also carry a crock pot and an electric roaster.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 01-06-2016, 04:06 PM   #19
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Tips:
  • Find a couple of pans that fit well in your oven.
  • Learn to make toast (broiler). That thing makes great toast.
  • Avoid spills at all costs - oven cleaning rots
  • If you have to cook a large item like a roast, ham or turkey - cut it in half.
  • Make friends with Rhodes frozen cinnamon rolls - they are awesome first thing in the morning and NOTHING smells better than hot cinnamon and coffee.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 01-06-2016, 05:36 PM   #20
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I found that things tend to burn on the bottom when cooked in the shallow oven of our "65 Caravel. I bought an insulated cookie sheet that will just fit into the oven and placed it on the metal sheet that separates the burner from the oven. This seems to keep the burner from overheating the bottom of what ever pan, cooking dish or cookie sheet is used to bake. It seems to force much of the heat to the top of the oven. That was several years ago, and has worked very well for us.
For a few bucks, you might give this a try.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 01-06-2016, 09:00 PM   #21
St Paul , MN
Could someone please post a picture of the tiny oven? I hear you on cleaning the oven! Has anyone used a silicone oven liner to keep the bottom of the oven clean?
Seemore2006 is offline   Reply With Quote
Old 01-06-2016, 09:58 PM   #22
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Toast. I have successfully made toast in out oven!
Having read this thread, a Dutch oven for a cassaroel or bread sounds like a wonderful idea!!!
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 01-06-2016, 10:09 PM   #23
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We put a digital thermometer in the oven. We chased the temperature continuously making small adjustments on the dial. Maybe the stone inside would help stabilize the temperature swings?
Old 01-06-2016, 10:16 PM   #24
Gsmblue's Avatar
Bend , Oregon
Absolutely. I use one in my home oven for that very reason.
microwave ovens gerry budden Stoves, Ovens & Microwaves 3 10-26-2008 07:19 PM
TINY, TINY parts repair JBK General Repair Forum 6 06-16-2006 03:19 PM
Speaking of Magic Chef ovens... Chuck Stoves, Ovens & Microwaves 4 06-16-2005 04:16 PM
