Old 05-30-2004, 05:58 AM   #1
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Battery Size
Hello. I am working on my 65 17' Caravel. I have a battery, Marine/RV but it is too big for the battery tray. What size battery fits in here? Thanks.
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-02-2004, 04:20 PM   #2
robandzoe's Avatar
Plymouth , New York
Battery size
I have measured the battery tray and it measures 6 wide by 13 long. No one here locally can get me a battery to fit in the tray. What battery are you using on your 1965 trailers? I want to keep using the tray. There was no battery in there when I got it, as the battery folks here want to see the old battery. Thanks all!
Rob
Plymouth, NY 13832
Courtesy parking
Old 06-02-2004, 04:33 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Rob
Rob, if your marine/RV battery is a group 24, it will say on the receipt, and on the battery, the next size down is a group 26. It is pretty small, but that may be all the room you have. My little Argosy takes the 26 also.
If they sold you a group 27, a 24 should fit.
And before you ask, group 26 is NOT available in a deep cycle.
Good luck with it.
Old 06-02-2004, 04:57 PM   #4
gvanman's Avatar
Howell , Michigan
Go to
http://www.exide.com/pdf/Exide_2002_catalog.PDF[/URL]
and you can download the Battery Application Guide - if you are on dial up, then this file is 6.8mb!!
The closest to your 6 x 13 size is a BCI Group 56 which is 10 x 6 1/16", but this is an automotive battery and would not be suitable for a cycling application.
Cheers,
Dave Harris
'If you always do, what you've always done.'
'You'll always get, what you've always got!'
http://www.dpharris.com
gvanman is offline   Reply With Quote
Old 06-02-2004, 05:25 PM   #5
robandzoe's Avatar
Plymouth , New York
Group 26
What are the dimensions on the Group 26 battery?
Plymouth, NY 13832
Courtesy parking
Old 06-02-2004, 05:39 PM   #6
Creampuff
Creampuff's Avatar
1957 22' Flying Cloud
1971 31' Sovereign
2014 25' Flying Cloud
Malibu , California
Images: 60
Rob:
I'm using a Costco Deep Cycle in my '67 Safari, which fits well width wise but is shorter than the tray. I've had good service from it and Costco just take 'em back with a really good non-pro rated warranty period. I had one go bad on the road and pulled into a Costco -was back on the road in 20 mins.
I would have to look at the group size ,but it's the only one they carry in deep-cycle marine.Reasonable too!
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 06-02-2004, 05:42 PM   #7
Well Preserved
1993 21' Sovereign
Length: 8 inches
Width: 6.75 inches
Height: 7.75 inches
Old 06-02-2004, 05:43 PM   #8
Well Preserved
1993 21' Sovereign
This is the group 24 dimensions:
Length: 11 inches
Width: 6.88 inches
Height: 8.75 inches
This one IS available in deep cycle.
Old 06-02-2004, 05:44 PM   #9
gvanman's Avatar
Howell , Michigan
The group 26 battery is:-
8 5/8 (L) x 6 3/4 (W) x 7 15/16" (H)
Old 06-02-2004, 05:47 PM   #10
robandzoe's Avatar
Plymouth , New York
My tray
The battey tray in the Caravel is only 6 inches wide. Could it be an incorrect tray..it is plastic. The tray is 6X13. Ugh!
Rob
Plymouth, NY 13832
Courtesy parking
Old 06-02-2004, 06:02 PM   #11
Well Preserved
1993 21' Sovereign
Rob
6" wide tray would limit you to groups 55, 56, 64. None are deep cycle batteries. If the base of the tray is the limiting factor, that is, if the box in the trailer is big enough for the larger battery, ditch the tray and get a bigger one. The group 24 "footprint" is the standard battery size, with a few variants in height.
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Oddball size battery, help! Jabba Electrical - Systems, Generators, Batteries & Solar 3 04-03-2003 02:23 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
battery size? larry smith Electrical - Systems, Generators, Batteries & Solar 2 08-12-2002 08:29 AM
