Old 08-17-2014, 12:03 PM   #1
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Anyone have any extra 9" original tiles laying around?
I just need a few of the 9x9 original tiles to replace the ones by the entry that died with the floor. I'm sure we can negotiate something.
If I can find 'em in ones or twos I'll be happy. I found some vintage 9x9 tiles on ebay a while back but they turned out to be too thick. I'm just trying to get by until we gut and re-floor in a few years
Jeepers! is offline   Reply With Quote
Old 08-17-2014, 06:26 PM   #2
1963 19' Globetrotter
Moline , Illinois
Just cut some down
If you are not worried about a color match , find some tile the right thickness that you like , and simply cut it to 9x9 with a framing square and utility knife. Thick stuff like Congoleum you can score and snap. You can also rent vinyl tile cutters. I did my trailer floor in 9x9 s that I cut down from 12x12s.
63air is offline   Reply With Quote
Old 08-17-2014, 06:30 PM   #3
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Interesting. Until we re-floor the unit simply retiling is the plan, and correctly I'm not concerned with matching at this time. I did consider cutting up sheet linoleum but your suggestion sounds better. I'll look into that. I'm only short 3 or four tiles, I had several already. Thanks!
Old 08-17-2014, 06:33 PM   #4
1987 25' Sovereign
Oregon , Ohio
I have been told that the old 9"x9" floor tiles contained asbestos and that when the industry stopped using it they went to the 12"x12" tile.
msmcv51 is offline   Reply With Quote
Old 10-02-2014, 05:44 PM   #5
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
I managed to scrounge up the needed tiles from under the old front "dinette". The front dinette was built by a previous owner and I ripped it out and built a permanent bed, there were still floor tiles I successfully managed to pull up and re-use.
Old 10-02-2014, 06:26 PM   #6
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I found a VCT cutter on Amazon for $90 (about 1/3 the retail price) Ordered boxes of Armstrong VCT tile in a color that could have been period, and it pulled out the color in the appliances. Have yet to have the time to install it, but I did notice they are about 1/16" thicker than the original asbestos type gold fleck tiles.
robwok is offline   Reply With Quote
FYI Notes Laying Out Fresh Water System Tony S Fresh Water Systems 0 09-04-2013 11:07 AM
'tricks' to laying a laminate floor? 59er Floor Finishes 4 07-06-2007 10:06 AM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 03:59 PM
Anyone have these AC items laying around hummerdinger Furnaces, Heaters, Fireplaces & Air Conditioning 6 09-21-2005 06:24 PM
