Old 01-17-2016, 08:33 PM   #1
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
'65 Caravel Hydroflame
I've taken the unit out of the trailer and it was in pretty good condition. I examined it thoroughly, intake exhaust, cabinet etc. the pilot hadn't lit in decades as far as I could tell, it was hopelessly plugged up and rusted inside. The thermocouple was corroded but operated. I replaced the pilot and thermocouple and the unit operates. HOWEVER...
I can light the pilot, adjust the temperature knob and the main burner ignites and it runs and warms fine until the target temperature is reached, then the unit clicks and shuts down. SHUTS DOWN COMPLETELY; the main burner AND pilot goes out. Sometimes it will actually cycle on and off a couple of times, but that's it. What could I look at next? The tanks are new and full, I've a new regulator, I've managed to get the original LP fridge working and managed a hack to get the oven running again (although the new pilot standing flame burns like a torch not a match flame), I've even pulled the rust bucket water heater and installed an instant on LP unit that works nicely. During all this LP refurbishment I blew out the old lines and checked thoroughly for leaks. But the heater has me stumped, it works - sorta.
Jeepers! is offline   Reply With Quote
Old 01-17-2016, 09:05 PM   #2
Ottawa , ON
You might want to read this thread They appear to have the same issue.
Best of luck!
Old 01-17-2016, 09:39 PM   #3
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Yeah, I've seen it...
It's several years old. I've read almost everything in the a/c & furnace forums plus everything in the Caravel forum too. Thanks.
Old 09-17-2018, 09:54 AM   #4
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Did you ever figure out what you problem was with the Hydroflame?
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 09-17-2018, 11:17 PM   #5
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
I have not. We picked up a household ceramic plug-heater, and had a rooftop AC/heatpump put on also. And not having been out in the trailer in freezing weather the furnace hasn’t been used. I suspect the pilot nozzle I put in was sub-par and/or the baffling allows it to be extinguished.
caravel
Need Help Dometic Penguin To A Hydroflame 18000 furnace 1963tradewin Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-28-2009 10:01 AM
HydroFlame heater removal, '65 Caravel SSTANK05 1965 Caravel 8 08-22-2008 08:23 PM
Removal of HydroFlame Furnace on '65 Caravel jlovelady Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-17-2007 09:10 PM
Hydroflame Incident Stefrobrts Furnaces, Heaters, Fireplaces & Air Conditioning 17 02-25-2005 08:27 PM
Caravel Hydroflame removal? Stefrobrts Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-11-2004 03:12 PM
