Old 01-27-2004, 11:51 PM   #1
sunnyhillfarm's Avatar
2017 25' International
Vancouver , Washington
Send a message via ICQ to sunnyhillfarm
Question 1965 Caravel
We would like to know the best method of making an accurate floor template for carpeting. Can you help us?? (this is our first new thread!)
Tony & Linda Starbird
sunnyhillfarm is offline   Reply With Quote
Old 01-28-2004, 04:41 AM   #2
Start with newspaper and a felt tip pen and tape to floor.
Push excess paper snug up the wall, mark vertex with pen,
Transfer to cardboard & cut out along ink line.
Dick
Navigator is offline   Reply With Quote
Old 01-28-2004, 05:28 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use what they used to call "red rosin" paper, it is available from your local home building center. I think they call it "builders paper" or "slip Sheet" it is a gray or brown color and available in the roofing section. It is stiff enough that you don't have to make the transfer to cardboard. What I do is get a piece fitted to one side by marking and cutting, then bring a piece in for the other side and do the same thing. When I am happy with the fit, while they are still in place on the floor tape them together with masking tape, then you have a full sized pattern. Hope this makes it clear.... I use it for making patterns for my vinyl too.
Aaron
Old 01-28-2004, 07:22 AM   #4
Zed2's Avatar
1993 21' Sovereign
Plano , Texas
Tony & Linda Starbird,
I also have a 1965 Caravel. Send me your email address, I'd like to exchange ownership experiences.
Keith
Zed2 is offline   Reply With Quote
Old 01-28-2004, 07:39 AM   #5
Chas's Avatar
Images: 22
You can also get a template kit at your local hardware store's vinyl flooring department. I think it is made by Mannington. It basically contains a bunch of paper and a tracing wheel that lets you create a full-size paper pattern of the floor which you then lay down over your one-piece of sheet flooring, carpet or vinyl, and then cut away.
I used it on my Minuet flooring which came out great!! It is basically designed for sheet vinyl but I see no reason you couldn't use it for carpet as well.
Chas
Chas is offline   Reply With Quote
1965, 1965 caravel, caravel
