Old 10-06-2006, 05:47 PM   #1
1969 18' Caravel
Sevierville , Tennessee
Question Will Water Pump Work on Battery?
Taking my "new" 1969 Caravel out for the 2nd time....and this time will be dry camping. The previous owner told me the switch at the sink is for the water pump. Does this work on battery? If not, guess I am out of luck for water in sink and commode. Please let me know....explain with short words as if talking to your grandma who doesn't know much about her Caravel, but is more than willing to learn.
Lone Rangerette is offline   Reply With Quote
Old 10-06-2006, 05:55 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The water pump is a 12 volt device, it runs off the battery or the convertor when plugged into shore power.
Richard
azflycaster is online now   Reply With Quote
Old 10-06-2006, 07:55 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
the pump and any other 12 volt device will work off the battery. Your house items like fridge, a/c, microwave and such will not. There is a converter you can buy, small and not expensive, that will let you run some small applainces off the battery as well. It converts 12v to house type current. Be aware though that without a generator or solar re-charging system, the battery will only last so long, depending also on how healthy it is. Be sure to check its water inside the cells if it has removable lids, and check its charge to see if it is full. You can do that with a voltage meter.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
Battery Slide Out niftypkg Electrical - Systems, Generators, Batteries & Solar 5 01-01-2003 03:41 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
