Old 03-30-2004, 01:58 PM   #29
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
John,
Very sorry to hear about the Classic. You know the labels you mention I thought were just for mounting the stabilizer jacks. I had no idea that you could jack up the coach from there.
Eric
Old 03-30-2004, 08:59 PM   #30
WayWard Wind's Avatar
2004 25' Safari
I had the same questions in regards to raising the unit to grease the bearing. Our unit does not have the attached riveted location plate & only has one sticker on the far rear cs. I e-mailed A/S tech & they findally sent me some photo's on where to place the jack. The location they picture was the frame where the shock absorber is fasten. Not any where close to the belly frame. I'm still not convinced it's the right area. I'll try to attach the pics if I can figure out how to load them with the new set-up.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 03-30-2004, 09:23 PM   #31
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I am with Andy, at least on teh vintage trailers.
I did put a jack unde the frame section rearwwart from teh axles, where the red arrow idicates a jack position. It deformed the outside skin, and caused the trailer to creak and groan like U571 at 500 meters.
I immeditely backed off the jack, and could see the skin pop back into position. Lifting at the axle plates did not cause any problems at all.
Maybe newer trailers have real frames? Mine has a puny gauge frame, and bends and flexes already when making semi-tight turns.
I guess it would not take much of an effort to bend the rearmost frame section as shown in the pictures.
Uwe
www.area63productions.com
Old 03-30-2004, 09:58 PM   #32
Aluminut
2004 25' Safari
. , Illinois
LOL!!!!
Old 03-31-2004, 07:35 AM   #33
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Just received a reply from Airstream
This conflicts with the info provided by Inland Andy on the link I posted earlier and that surprises me. I'm sure that Andy's opinion is based on his many years of experience. I have never known him to provide incorrect information and there must be sound logic behind his opinion on this topic. Perhaps he will read this and share more of his wisdom with us.
Here's a copy of the email:
Roger All trailers are provided with a 3" aluminum pad to indicate the proper jack placement position. It is located on the frame rail behind the rear tires.
Airstream does not recommend placing the jack under the axle or axle mounting plate.
Tim Maxwell
_____________________________________
Thank you,
Customer Service Representative
Airstream
Rog0525 is offline   Reply With Quote
Old 03-31-2004, 07:55 AM   #34
2004 25' Safari
Trailer damage due to improper jacking
O.K , going to try to post a pic of the location A/S tech sent me via e-mail. We have no 3x3 pad attached under our unit & the location that this photo shows DOES not relate to the location I have seen on other units. I can't understand A/S confusing messages on this problem.
Best,
Name:	Trl Jacking Point #1.jpg
Bogfrog & Mr. Turbo
Old 03-31-2004, 08:01 AM   #35
2004 25' Safari
It worked. the silver strip showing is the start of the wheel well. According to A/S & the way I understood their e-mail that the jcking point was under the bracket where the shock is attached. You can see that the bracket appears to be about 1" wide. I really aim concerned raising the unit with only that much area.Most jacking locations I've seen is right behind that silver strip, however iI'm not sure of what's under the skin & if it's strong enough to raise the unit.
Best.
Bogfrog & Mr. Turbo
Old 03-31-2004, 10:26 AM   #36
Rog0525's Avatar
Images: 11
Thumbs up Just got good news
The RV rep showed up shortly after my last post. He did not admit to any liability but he was very courteous and agreed to tow it back into the shop to be repaired at no charge.
I guess you won't be seeing me on Judge Judy's show.
Rog
Old 03-31-2004, 02:42 PM   #37
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
I discovered that my trailer has added in jack plates. What a bonus!
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 03-31-2004, 04:20 PM   #38
Aluminut
2004 25' Safari
. , Illinois
Rog...shocked you didn't give them this (sorry to shamelessly steal!):
Old 03-31-2004, 05:02 PM   #39
Rog0525's Avatar
Images: 11
LOL Eric. As it turned out I didn't need my shootin' iron after all.
The guy was quite nice and the trailer is repaired and back home already. Not quite as good as new but good enough. I don't know what kind of tools they used but the whole job only took about 2 hours.
You can bet I'll be asking about their jacking methods before I ever leave the trailer in an RV shop again.
Hopefully they learned somthing from this experience also.
Rog
Old 03-31-2004, 05:35 PM   #40
Aluminut
2004 25' Safari
. , Illinois
Urgent...Jacking trailer hhuber Jacks, Stabilizers, Lifting and Leveling 20 10-06-2003 10:47 PM
Frame rust Ken J Repairing/Replacing Floor &/or Frame 5 07-13-2003 06:39 AM
Door hinge/frame damage Dennis Fahlstrom Doors & Locks 1 07-04-2003 11:50 AM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
