Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1969-1971 Caravel
Old 02-26-2006, 12:20 PM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Tow Vehicle for my '69 Caravel
Hi,
I'v pretty much figured out that my 2005 Hyundai Tuscon is not capable of comfortably towing the Caravel ; it's close with a maximum towable weight listed as 2000lbs & a GVWR of 6650lbs (the maximum tongue weight is 150Lbs though).
Therefore, I'm looking for a cheap short term tow vehicle (I'll likely have to sell the Caravel mid summer ). I thin ksomewhere in the forum I've seen a Caravel being towed by a Chevy Astro van (or perhaps a Safari). Does anyone have some recommendations..have they tried this combination.
Obviously, safety is #1, cost isa close #2. I'd like to make a couple of trips (~ 500km before I'll need to sell).
Thanks in advance
Julison is offline   Reply With Quote
Old 02-26-2006, 01:33 PM   #2
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Julison, according to the Airstream weight chart, your '69 Caravel weighs 2880 lbs with a 360 lb tongue weight. That puts it well out of the range of towing it with your Hyundai.
I have towed a '61 Bambi with a '98 Astro. As long as you have good, solid sidewall tires on the Astro, and you use a weight distributing/sway control hitch you'll be amazed at how well an Astro will tow. As a matter of fact, it's almost an ideal tow vehicle IMHO for anything under 3500 lbs dry. It's max tow rating in the AWD version, as I recall, is about 4800 lbs. I wouldn't suggest the 2 WD version as they are really squirelly in reduced traction situations. The AWD version however is like a mule. They're quite remarkable, and the 4.3l V6 is a tried and true workhorse. I only traded my Astro off when I bought my Y2K Excursion, and even now three years later, I still wonder if it was the right thing to do!
Good luck!
Roger
85MH325 is offline   Reply With Quote
Old 02-28-2006, 02:18 PM   #3
1966 17' Caravel
St. Petersburg , Florida
Send a message via AIM to Bob Lindstrom Send a message via Yahoo to Bob Lindstrom
Tow Vehicle
Julison,
We pull our '66 Caravel with our '2001 Toyota Sienna. With the Reese Equalizer hitch it works well but we have careful not to overload. And its more comfortable than my '66 Ford F250.
Joycee & Bob Lindstrom
St. Pete, Fla.
'66 Ford F250/'66 Caravel
Courtesy Parking - Under 24 Feet.
Bob Lindstrom is offline   Reply With Quote
Old 02-28-2006, 02:37 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
At 6600lbs, you want something with some meat to it. Not sure on the length of your trailer but a Trailblazer (the extended one) seems like a good fit too. If you load it to near the 6500 and add passengers, cargo, fuel, etc you start to get to the 3/4 ton things like Suburbans, pickups, etc. If the coach is longer, then the longer the wheelbase, the better.
If your trailer loaded is under 6500lbs (say 5000, 5500lbs), any 1/2 ton or equiv should do, but verify the vehicles specs to make sure.
caravel
Por 15 for hitch parts dznf0g Hitches, Couplers & Balls 7 03-20-2012 12:39 PM
Need some parts for a window clean up ND10CentCan Windows & Screens 43 03-19-2012 05:35 PM
Cutting hole for 75 Argosy AC DearArgosy Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-19-2012 04:32 PM
Subfloor Prep for Laminate Hardwod - ? mountainsun Repairing/Replacing Floor &/or Frame 4 03-19-2012 04:15 PM
Member who used IKEA baskets for drawers? funkill Cabinets, Counter Tops & Furnishings 3 03-19-2012 12:07 PM
