Join Airstream Forums Today
Old 08-09-2009, 11:01 AM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Replacement Fridge for my 1969 Caravel
Hi,
My fridge is not cooling and I'm sure it has leaked it's coolant based upon a yellow residue around the burner.
I'd love to fix if possible but all my investigations have pointed to this not being possible (not sure why a leak cannot be fixed and the unit recharged...but I'm far from being an expert.
Therefore, does anyone know where I can buy a replacement that won't require me to modify the existing cabinets? The trailer is close to original and I'd like to keep it that way.
My Model is MA40C and says Dometic on the door but has Electrlux on the id plate. A previous enquiry in the Reefer Forum indicated that Dometic had no history of this model.
thanks in advance,
Julison is offline   Reply With Quote
Old 08-09-2009, 11:45 AM   #2
Grand Master's Avatar
1963 24' Tradewind
Anderson , Indiana
Dometic Freedom RM 2410 or RM 2510 should be the correct width. Newer models are about 1" wider. The 2510 is taller.
Mike Brumback
1963 Tradewind
Grand Master is offline   Reply With Quote
Old 10-19-2009, 03:55 PM   #3
1969 18' Caravel
Fruita , Colorado
I'll take your old door
My fridge works but the door is tweaked. Let me know.
kenaldo is offline   Reply With Quote
Old 10-19-2009, 04:37 PM   #4
Jim Foster
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The fridge in our Caravel developed a leak while on a trip to the east coast. The unit was in otherwise good shape. I was able to have the cooling unit replaced. It was less than the cost of a new unit, even with the labor. I could have changed it out myself, but was able to get professional help for a hundred or so bucks and found it well worth it.
Old 10-19-2009, 06:48 PM   #5
Ganglin's Avatar
1971 27' Overlander
Gahanna , Ohio
Images: 13
You might check with this company to see if they can rebuild it...
RVCOOL.COM - Supplier of rebuilt cooling units for Norcold and Dometic RV Refrigerators.
GARY
Charter Member - NOVA
WBCCI - 5308
INFORMATION AT: http://www.campnova.com/
Old 07-05-2011, 09:22 PM   #6
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
So happy to say that I finally found a replacement Dometic for my Caravel. Removed the old one and replaced with the used one a couple of weeks ago. Just came back from our first trip and it performed flawlessly. It was 30C outside and the fridge stayed at 3C and the freezer at -11C. Sooooo nice not to have to wrestle with coolers and ice.
The cold beer were great too.
Old 04-30-2012, 05:09 PM   #7
vanster's Avatar
1967 17' Caravel
Oakland , California
How on earth did you find a replacement?
Ours went out on our way to SF from Madison WI
vanster is offline   Reply With Quote
1969 Caravel Outside Receptacle Replacement Julison Lights - Interior & Exterior 4 08-08-2009 09:53 PM
1969 Caravel Owner vloca Member Introductions 7 08-01-2009 10:52 AM
Value of modified 1969 Caravel slvrpassion Trailer Values 10 04-15-2007 04:43 PM
Just bought a 1969 or 70 Caravel LilBean Member Introductions 5 10-11-2006 10:04 AM
Gross wt of 1969 Caravel? daigledesign 1969-1971 Caravel 2 04-07-2006 12:18 PM
