Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1969-1971 Caravel
Old 10-01-2007, 08:43 PM   #1
Julison's Avatar
Profile:  1969 18' Caravel
Ottawa , Ontario
Rear Window Dilemma
Hi,
I unfortunately broke the rear window on my 69 Caravel.
No big deal, remove the frame and bring it to my auto glass place.
3 weeks later (-$75 for the tempered glass) the window and frame are back and I can install.
Problem #1:While installing I notice the frame is pulling apart..Mmmmm.
Check it out and the guys at the glass shop drilled too large a hole and bisected the metal corner bracket that holds horizontal piece to vertical piece. Again, no big deal, I fabricate a new corner bracket out of a large gauge nail (bent at 90 and ground down to proper size).
Problem #2: While installing, the window does not seem as free moving as before and kind of hovers an inch out from flush against the trailer. What's more annoying is that even when I manage to get the window flush against the jamb it is approx 1mm lower than it ever was...causing the window lock clasp to but up against the jamb. How can the window be lower...the corners all seem square and tight.
ANy ideas on what has happened? It's a mystery to me.
thanks in advance,
Julison
Julison is offline   Reply With Quote
Old 10-01-2007, 09:11 PM   #2
Commercial Vendor
Profile:  Corona , California
Originally Posted by Julison
Hi,
thanks in advance,
Julison
Rebuilding old Airstream windows is near impossible as you have learned.
Replacing them is the only "for sure" answer.
You cannot take an old window sash apart and put it back together again, without getting into a number of different problems.
Contact your insurance company, and replace the window with new.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 10-02-2007, 08:34 PM   #3
Julison's Avatar
Ottawa , Ontario
Thanks Andy,
You may be right.
But, having gutted the trailer to replace the frame and floor - I can't be stopped by a window frame. Technically, it's dead simple - right?
I'm not certain (as I didn't anticipate the problem and premeasure the window before I sent it to the glass shop) but it must be slightly bigger.
I will pull it apart myself and reassemble - this time ensuring every last millimeter of play is taken up.
I'll keep you posted.
thanks again
Pingbacks are On
Rear window replacement...please help! Mark&Bet Windows & Screens 15 08-25-2006 09:44 AM
Rear window awning azflycaster Awnings 10 03-22-2006 06:01 AM
How wide is a rear window awning? RichardT Our Community 3 01-31-2005 12:14 PM
rear window wanted! tinsltootsie Parts Archive 1 06-24-2004 09:39 PM
Window latch dilemma maxandgeorgia Windows & Screens 4 04-20-2004 01:40 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
