Old 01-04-2013, 04:06 PM   #1
vanster's Avatar
1967 17' Caravel
Oakland , California
gutted
Our Caravel is now almost gutted
Now for the fun part
We are now making a complete interior from cardboard
Then we will have an idea of where to put in water tanks and electrical etc
ID:	175913   Click image for larger version
vanster is offline   Reply With Quote
Old 05-27-2013, 02:25 AM   #2
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
So are you any farther on the redo? getting ready to pop the shell off on our 66.
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-28-2013, 04:01 PM   #3
vanster's Avatar
1967 17' Caravel
Restore the Caravel
We were just about to dive into it about 45 days ago. Then we decided to go to the Vintage Trailer workshop in New Mexico first. Had we not gone I think we would have made some huge costly mistakes.
We worked on it all this weekend. Got the belly pan half way off along with the the rub rails, built a support structure inside for the lift off.
and discovered a broken crossmember in the frame. Not a big deal.
I think we should have the shell off in a few weeks. Just other stuff to do.
We have changed the interior design a number of times. It's seems slow at the moment but I think we will catch up soon. This weekend we have to go to San Diego and on our way back we are going to stop by Area 63 and chat with Uvey.
We need to order tanks to go under floor. Also I am going to hang the spare tire under the floor as well. I understand that there are captive nuts in place just for a tire rack.
Old 08-12-2013, 01:56 PM   #4
vanster's Avatar
1967 17' Caravel
We are back into charging ahead with our shell off project
We have removed the under panels and all of the insulation. We found one broken outrigger and one broken frame weld. The frame all in all appears to be in good shape.
We left the C channel inplace and we used Cleko's to keep the C channel attached to the shell.
We will be using the old belly pan as a template for the new one
Next is to lift the shell off and pull out the frame. I am going to media blast the frame and re weld. Paint with POR 15, Build a spare tire rack and install a water tank over the axle then put the floor on then the shell back on.
We need to take out the windows before we take the shell off
Any tips for this?
Name:	Belly pan A.JPG
Old 08-13-2013, 01:23 PM   #5
1966 17' Caravel
You did an awesome job of removing the belly pan mine was ripped so the removal did not go so well. I have the flipping yoke ready to use and will be doing the frame soon!
Cliff
Old 08-27-2013, 10:32 AM   #6
vanster's Avatar
1967 17' Caravel
Shell OFF !
This weekend we got the shell off and now the fun begins. Need to get the frame sorted, order a water tank to place in the center. Weld a bracket for the spare tire. Frame needs to be re-welded in spots only one broken out rigger.
The plywood floor had more rot than originally thought. ( note we took the windows out before we took the shell off)
Next step is to clean the frame and paint it with POR 15. I'm going to use grey rather than black. Make a new floor using marine ply. The plan is to take it to a marmoleum shop where they can layout the material roll it with their equipment and heat seal the seams. This could be a DIY but it's really important to do this step correctly.
Then to put the frame back under the shell and replace the windows
ID:	194304   Click image for larger version
ID:	194306   Click image for larger version
Old 08-28-2013, 12:47 PM   #7
1966 17' Caravel
I did not remove any windows and left the c channel on the floor braced the shell then lifted the shell off soon I hope to be putting the shell back on! Our belly pan was in too bad of shape to use as a temp plate and mine has no room for a water tank under the floor are you mounting it inside the trailer? Yours looks awesome so far! Great job.
Cliff
Old 08-29-2013, 10:30 AM   #8
vanster's Avatar
1967 17' Caravel
This weekend we are going to clean up the frame and paint it with POR 15
Then we have to figure out where to put the water tank. I am going to put the tank below the floor. The problem is that the water tank needs to be 6 to 8 inches in depth I am told. Maybe I will have to put in just in front of the axle.
I don't know if we had to take out the windows or not but the curved Corning windows are about $600 each if you can find a replacement.
Then I need to weld in a bracket for the spare tire
Onwards!
Old 08-29-2013, 10:34 AM   #9
vanster's Avatar
1967 17' Caravel
I left the C channel in as well. It seems to be in good shape. Now we are thinking of a cork floor covering
Old 08-29-2013, 10:47 AM   #10
65CV's Avatar
Western , Massachusetts
Looking good!
We fit a grey tank above the axle and I think I calculated it to be about 24 gallons. See Post 52 onward in this thread. I think the stainless cost us $165.
65CV is offline   Reply With Quote
Old 08-29-2013, 03:08 PM   #11
1966 17' Caravel
I like your idea but for now I will stick with the blue beast. I understand about the windows and when we lifted the shell we had them open to reduce the stress. I removed the outrigger that the welder put on and was getting ready to weld on the one I made when mother nature said break time with a down pour! Right now time is not on my side with work and watching the grandchildren! Gotta make more time or demand it! Hopefully the weather will cooperate.
Cliff
