Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1969-1971 Caravel
Old 08-05-2008, 03:02 PM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Front Window Oddity - '69 Caravel
I have looking at some other images of 69 Caravels.
In doing so I've noticed an oddity with my front windows.
The curved windows are rounded at the front and bottom, but the skin surrounding them looks as though it was intended for a square bottom window. The patch work done to the skin has me wondering if some PO did the modification - would the factory do something like this?
Julison
ID:	65126   Click image for larger version
Julison is offline   Reply With Quote
Old 08-05-2008, 03:30 PM   #2
Julison
1969 only, trailers had 3 square corner and 1 radius corner wing windows.
They are expensive.
They can be replaced with wing windows from the 1970 and up models, which are also cheaper, which have 2 square corners and 2 radius corners.
When that takes place, the lower, outer missing square corner, must be plated in, as your photo shows.
There are a number of 69 trailers that have the newer style wing windows, the same as yours.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-05-2008, 03:48 PM   #3
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Thanks Andy,
So you think it was done after market and not OEM?
J
Old 08-05-2008, 03:54 PM   #4
Thanks Andy,
J
Absolutely correct.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-05-2008, 06:51 PM   #5
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Nice job for aftermarket!
caravel
Rivets for window rock guard hinge arcamedies Rock Guards, Segment & Window Protectors 5 12-30-2012 06:20 AM
310 window latches montreal Classic Motorhomes 4 03-20-2012 12:55 PM
Front Window Support arm pickerdd Windows & Screens 2 03-20-2012 05:53 AM
Need some parts for a window clean up ND10CentCan Windows & Screens 43 03-19-2012 05:35 PM
Hehr 1964 window glazing strips GlobeTrottin Windows & Screens 1 03-18-2012 12:18 PM
