Old 10-17-2005, 02:32 PM   #15
Images: 59
To replace the back 4 ft, fabricating everything from new steel, for $1100 CD sounds good to me.
As with anything, workmanship is important. If they do a good job, chip the welds, make it nice, it's worth it. If they do a crappy job it's no bargain.
Old 10-17-2005, 06:44 PM   #16
StingrayL82's Avatar
San Angelo , Texas
Images: 37
That's a little over $930 US.....really good deal, if you ask me, considering the time, materials and headache involved. Of course, like Mark said, provided the workmanship is worth a darn.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 11-25-2005, 06:40 PM   #17
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
I got the trailer back....finally (2 months to complete) and he did a decent job of the welding. He replaced everything from the wheel well back and included new outriggers. My only complaint is that he said it would likely be a slightly heavier gauge of steel ...when infact it was a slightly lighter gauge of steel. However, it appears very sound and sturdy - so I'm happy with it.
However now it is winter and I've got to replace the floor in the snow
By the way, has anyone ever tried to use std polish techniques in sub zero weather? I wouldn't mind trying to get this trailer polished over the winter.
thanks in advance,
Julison
Julison is offline   Reply With Quote
Old 11-25-2005, 10:13 PM   #18
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Glad to hear you got it back. Hopefully the lighter steel won't be an issue. A lot of the strength comes from the complete unit assembly, so hopefully everything else will make up for it when it's all put together.
Putting the floor back in isn't nearly as bad as taking it out was! You're on the home stretch now.
Stephanie
Old 11-26-2005, 06:52 AM   #19
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Julison,
What do you mean by "lighter" gauge steel? If you mean a smaller number 14 as opposed to 16 that would be correct, the thicker the steel the smaller the number, if it mics out thinner I would want to know why, and what type of steel.
Aaron
WBCCI #XXXX AIR #2495
Old 11-26-2005, 07:12 AM   #20
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Originally Posted by wahoonc
Julison,
Aaron
I didn't use a gauge to measure it exactly.....but it appears to be a thinner gauge (higher #). The garage said that it just looks thinner because of the rust on the surface of the existing frame. mmmm Maybe, if it is thinner, it is only slightly so. I'll snap a couple of pics later today maybe.
AS for the type of steel... I no sure. It's not galvanized for sure. I've just received some POR 15 to seal it up.
Julison
Old 11-26-2005, 09:26 AM   #21
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Julison
The rust making it look thicker makes sense also coats of paint, though from what I have seen of painted rv frames I find that a bit hard to believe POR-15 is the only way to go, we just finished the frame on a 57 Chevy with that stuff, make sure you don't get too much on you...it has to wear off
Aaron
Old 11-26-2005, 11:05 AM   #22
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Where are you located?
If you are anywhere Minneapolis MN give me a call. 612 968 5248
I've welded/repaired a couple of AS frames now and you will like my prices very much.
Jerry
Ultradog is offline   Reply With Quote
Old 11-26-2005, 11:07 AM   #23
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Julison,
what snowy part of Canada are you in?
Sergei
SmokelessJoe is offline   Reply With Quote
Old 11-29-2005, 12:55 AM   #24
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Originally Posted by SmokelessJoe
Julison,
Sergei
Hi Sergei,
I'm in Kanata, Ontario....just outside of Ottawa.
Julsion
caravel
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
