Old 07-31-2008, 10:51 PM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Belly Pan Replacement
Hi,
Just came back from our 10 day tour of Ontario, Canada.
Love the trip. Actually saw another vintage Airstream - first one I've seen (being used) in my travels up here. THe whole trip has got me primed to finish up my rebuild of the trailer (I previously had replaced the rear frame and floor). Last task is to replace the belly pan. I kept the old one as for a template - it is far to corroded to reuse.
My question, what is a good replacement material and where can I get it in Canada if possible.
A couple of pics of the trip.
thanks
Julison
ID:	64843   Click image for larger version
ID:	64845   Click image for larger version
Julison is offline   Reply With Quote
Old 07-31-2008, 11:40 PM   #2
BarryIowa's Avatar
Polk City , Iowa
Belly Pan
What a great looking trailer! I just bought a 1962 Overlander - 26'. I'm fairly certain that the belly pan is the same gauge and grade of aluminum as the rest of the trailer which is aircraft grade. I am new to this so I apologize if I'm wrong. Good luck.
BarryIowa is offline   Reply With Quote
Old 08-01-2008, 06:46 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Any alloy of aluminum will work for the belly pan. You don't need to spring for the cost of the .032 2024-T3 that the trailer is skinned with. Any of the following alloys will be fine
6061
5052
3003
Kip
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
Belly Pan Opinion Please PoconoAir Belly Pans & Banana Wraps 14 05-09-2007 08:11 PM
belly pan aluminum? where? pinkflamingoes Belly Pans & Banana Wraps 33 11-03-2006 08:33 PM
Belly pan corner replacement Dan Clayton Belly Pans & Banana Wraps 12 09-27-2005 09:01 PM
Belly Pan Removal... aviontt Belly Pans & Banana Wraps 2 07-02-2004 04:47 PM
