Old 09-22-2005, 07:18 PM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
'69 Caravel, light switch
Hi,
So I've got my Caravel home. See pics.
It does require a bit of work, but I'm looking forward to it.
I've finally given it a good once over and realize I've got a bit of floor replacement to do - the back area that has the battery , Univot, water tank has a fair amount of rot. No worries.
I've got some of questions though.
#1) What is the switch immediately to your right as you enter the trailer (behind the fake window curtain)?
#2) What was the original "sound system" in this trailor. It's currently set up with a nice Pioneer 8 track.
#3) What originally covered the front windows on the outside...it seems to me that there was something there as a previous owner patched some rivet holes with some awful white silcone. How can I remove that goop?
#4) Finally, what IS Vulkem (Chemically)?
thanks all in advance,
ID:	14730   Click image for larger version
Name:	AS Back Left.JPG
Name:	AS Front.JPG
ID:	14734   Click image for larger version
Name:	AS UnderBelly.JPG
Julison is offline   Reply With Quote
Old 09-23-2005, 12:02 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Hi Julison.
That'a a great looking coach. Congrats!
1. The light switch you mention should be for the round porch light.
2. The Pioneer 8 track sounds like original equipment but may have been added by a PO.
3. There may have been a rockguard on the front window formerly. The '69 rockguards were quite flimsy and not very durable. You should be able to remove the goop with mineral spirits and a plastic scraper OR you can order a new rockguard from an AS dealer.
4. Vulkem data sheet:
http://www.reuse.org/Products/Joint%.../VULKEM116.pdf
Enjoy your new toy.
Rog
May you camp where wind wont hit you, where snakes wont bite and bears wont git you.
Rog0525 is offline   Reply With Quote
Old 10-05-2005, 09:54 AM   #3
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
2nd mystery switch on 69 Caravel
Originally Posted by Rog0525
Hi Julison.
Enjoy your new toy.
Thanks Roger,
You are right, it does turn on the porch light, however there is a second identicle switch a few inches away behind a curtain that doesn't seem to do anything...ideas anyone?
Julison
Old 10-05-2005, 10:48 AM   #4
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
I had mystery switch on my '67 Tradewind. It turned out to be for the water pump.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 10-05-2005, 12:00 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My water pump switch is in the kitchen near the sink. It's the only switch in the trailer. Is yours near the kitchen?
Stephanie
Old 10-05-2005, 12:05 PM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Check and see if it is connected to the light over the galley. That's the way it is on my '73. Its not exactly a "3-way" switch; but power to the galley fixture goes through this switch on the door. with that switch in the "on" position, you can then turn the light over the sink on and off; with the wall switch in the "off" position, the galley light won't work at all.
If you leave the galley light switch in the "on" position, you can use the switch by the door to turn it on and off, which lets you easily turn on an interior light as you enter the trailer in complete darkness, without having to fumble or feel your way around for another switch.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-05-2005, 04:51 PM   #7
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Mystery Light Switch
I have a switch over the sink that powers the water pump.
Then there are the two switches beside the door - one is definitely for the proch light..the other mmmm.
I'll check and see if it is tied into the dome or galley lights - there's not much else it could be.
thanks,
Julison
Old 10-05-2005, 06:48 PM   #8
2005 22' International CCD
Buckhorn , Ontario
Hi Julison
The switch is definately for the "Salon" light - the light that is in the middle in the ceiling that is over the couch or dinette - which ever you have.
Turn on the light - to the level you will mostly use - then go to the switch and press it up or down to turn the circuit off. It is a convenience when you open the door you can put a light on right away - without having to muddle around in the dark.
We had the exact same swith in the GT and.....asked the exact same question 2 years ago. We got thrown off by the reply saying it was the Galley light - as we had a light over the sink as well as the one in the center. But after a while the "little light came on"
Sounds like you are having some fun with your new acquisition.
05ModPod is offline   Reply With Quote
Old 10-09-2005, 08:01 PM   #9
Barkingdogg's Avatar
Newcastle , Oklahoma
Hi Julison,
You will grow to love your AS.
I have a 67 Caravel. I am giving you a link to a site for a product that I think is great. http://www.polyall.com. If you still have fiber existing in your rotten flooring ,this product will solidify them. I have used it on my Caravel floor and even on rusted steel on my 88 Nissan I use to pull my fishing boat. I do not like to throw things away when they are still good or can be repaired. It has the consistentcy of water so it penetrates where water has been but then turns to plastic. Can be drill, screwed, or sanded. Check it out. Even if you have rotted wood, but no holes, or can block holes, where polyall will run through, this will solidify.
Barkingdogg
Barkingdogg is offline   Reply With Quote
Old 10-10-2005, 04:18 PM   #10
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Originally Posted by Barkingdogg
Hi Julison,
Barkingdogg
Thanks for the info...looks a lot like a product (Git Rot) I used to use on a rooting old wooden boat I once owned. It's funny, but dry rot seems to follw me around....First the boat (58 Lyman lapstrake - beautiful boat), then my house (an old cottage on the OTtawa river that we just finished renovating) and now the Caravel. I hope the Carvel costs less than the house to repair
Julison
caravel
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 10:03 PM
Light switch question SilverHoot Lights - Interior & Exterior 10 07-15-2011 08:44 AM
2006 Safari Interior light switch Goal15 Lights - Interior & Exterior 7 05-03-2011 01:36 PM
Light switch over sink in '65 Caravel TANK FAMILY 1965 Caravel 8 04-08-2011 09:34 AM
