Old 09-30-2005, 07:57 AM   #1
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
'69 Caravel - Identity of Roof Vents
Hi,
I was hoping that someone could help me identify the various vents and the like that are protruding the roof skin. In addition, a previous owner has covered over some old vents....what was likely there?
Here is a pic:
thanks in advance,
Julison
Julison is offline   Reply With Quote
Old 09-30-2005, 08:14 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Julison,
A) Sewer
B) Might be cooktop vent fan exhaust?
C) Refrigerator
D) & E) Not sure but one of them might have been the television antenna (unless yours is already mounted on the front like mine is).
Tom
Old 09-30-2005, 08:24 AM   #3
till's Avatar
Lisle , Illinois
Images: 108
Tom hit A,B and C right on.
D looks like the base for the roof mount antenna that is on my 67 Overlander.
E....got me.......
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-30-2005, 09:12 AM   #4
Julison's Avatar
1969 18' Caravel
Ottawa , Ontario
Thanks for the vent id info..and now... how about
E....got me.......
While removing the belly pan I noticed a screened off area cut in the belly pan. The area is directly below the Dometic fridge. There is also a screened off hole in the floor - again just below the fridge.
Is this some kind of after market ventilation for the compressor?
an ideas would be appreciated. If it's not needed I'd like to create the new belly pan without the screened off area - there was a decade of dirt inside the belly area and and on the wall in the cabinet behind the Dometic.
Old 09-30-2005, 09:17 AM   #5
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Julison,
That is a vent to allow for air convection so your fridge can cool. It's factory, not aftermarket. Your fridge (if original) has no compressor. It is of the ammonia-absorption type. You can learn all about how they work here:
http://www.rvmobile.com/
Roger
caravel
Info on '68 roof vents. Nomadtek Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-22-2011 11:47 AM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
Roof Vent Insect Screen Installation Guym General Repair Forum 2 05-06-2011 07:08 AM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
