Old 05-09-2012, 02:30 PM   #1
1986 32' Excella
Bellaire , Texas
Zip Dee Awning
Greetings,
I've got a problem with the big awning on my 86 Excella. As I try to pull the awning out it gets stuck after coming out about 2 inches. It feels like is is stuck or "hanging up" on something. All latches are released but I can't budge it after 2 inches. Has anybody else had this problem?
There is a little "lever" in the top right hand corner and I have tried in in both positions....but to no avail.
Thanks for any thoughts you might have!
vicn2000 is offline   Reply With Quote
Old 05-09-2012, 02:41 PM   #2
Originally Posted by vicn2000 View Post
Greetings,
Call Linda, at Zip Dee.
1-800-338 2378
Old 05-09-2012, 03:43 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Is it getting hung up on the stove vent? I had that issue (wore a hole in the awning) until I made a modification to the vent on my '86 Sovereign. If not, they usually do take a big of a tug to get them going.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-10-2012, 08:19 AM   #4
1986 32' Excella
Bellaire , Texas
Thanks so much for your replies guys.....I will give it a whirl.
Have a fabulous day!
Vic
Old 05-10-2012, 09:29 AM   #5
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
The little lever should be in the "out" position. It is a lock for the reel.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-11-2012, 11:33 AM   #6
1986 32' Excella
Bellaire , Texas
Many thanks Aviator,
The lever is in the out position....but still not working. I called Zip Dee and they said the lock could be broken and may need to be replaced....hmmm. A couple of friends are coming over tonight and maybe we can just "horse" it out of there. I guess if the little lock is already broken I can do too much damage at this point.
Thanks again!
Vic
Old 05-11-2012, 12:07 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It sounds like you have a Z lock. Inside there is an alloy gear with teeth that often break and cause it to get stuck. If you keep jiggling it you may get the teeth to engage so you can open it. If you take it apart you can move the gear 180 degrees so the broken teeth are not being used and get some more life out of it. But if I was going through that much trouble I would just replace the Z lock unit.
If you end up messing around with the spring end of the roller be careful. It bites!
