I would like to know the exact half-measures gladly of the airstreams
know because I am trying to get an airstream to the Netherlands, but
the up to permitted breadth in the Netherlands is 2,55meter/8.3640
feet. I heard that there a couple models that are no breeder
then 8.3640 foot
can somebody tell me more???
You will need to avoid the newer "wide body" trailers. I'm not sure which year they were introduced, but they are 8'-6" wide whereas the non-wide body trailers are closer to 8'-0".
Tie a rock to a string
Hold (or tape) string to widest point on trailer - letting rock dangle to the ground.
Make a mark on the ground where rock touches.
Repeat for other side - using same point on opposite side of trailer.
Using a tape measure - measure distance between two marked points on the ground. No calipers needed.
Or.... you could remove the tree.....
1964 Globetrotter | 2023 Nissan Armada
