Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 01-01-2003, 08:30 PM   #1
dinoburb
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Question What is an Ambassador Model
Hi Airstreamers,
This is my second post. I have been looking for an A/S and have stumbled upon several, but not to my liking. However, I have a lead on a 28' Ambassador, late '70s. What do the various designations mean in this era, i.e.: Sovereign, Overlander, Excella, Ambassador, etc.? What should I expect with an Ambassador model?
Any help is appreciated.
Take care,
Sean
dinoburb is offline   Reply With Quote
Old 01-01-2003, 08:56 PM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
What is an Ambassador Model?
Greetings Sean!
Airstream Land Yachts of the 1960s through 1970s were typically identified as follows:
Sovereign of the Road - - 30' or 31' depending upon year
Ambassador - - 28' or 29' depending upon year
Overlander - - 26' or 27' depending upon year
TradeWind - - 24' or 25' depending upon year
Caravanner - - 25'
Safari/Flying Cloud - - 22' or 23' depending upon year
Globetrotter - - 19' or 20' depedning upon year
Caravel - - 17' or 18'
Bambi II - - 17'
Bambi - - 16'
During much of the above time, International was a trim level available on virtually every Land Yacht. What was included in the package varied by year, but usually included a water filter, some specific interior trim items and in some cases ventilation fans and/or lighting upgrades.
The URL below will take you to a site with plentiful information about Vintage Airstreams.
http://www.vintageairstream.com/archives/index.html
Basically, the Ambassador will be a tandem axle trailer with either of two typical configurations. One configuration, called a double, features a center coach bedroom with a fold-out double bed facing a wardrobe closet wall. The second configuration, called a twin, has a center bedroom with a twin bed on either side of the aisle. The coach would have typically had a rear full bath with tub and shower and a wardrobe closet next to a linen closet in the bath area. (It is possible that the coach might have a side bath depending upon its actual placement within the 1970s era. The kitchen will be immediately to the left as you enter the door with the lving room to your right - - actual configurations could include a single front lounge with side chairs, twin lounges (one front and one streetside), and if I am not mistaken, a dintte type arrangment may also have been available.
A late 1970s Ambassador will likely have a dry weight around 5,000 pounds with an actual towing weight of around 6,500 pounds when fully loaded for a vacation.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
test
