Old 07-17-2015, 04:39 PM   #1
1972 27' Overlander
Woodburn , Oregon
Water pump what to buy?
I have a 1972 overlander and I'm replacing and up dating everything so what would you folks recommend for a good water pump with brand and model ? I'm in the dark on this subject
shineybullet is offline   Reply With Quote
Old 07-23-2015, 07:44 PM   #2
1972 27' Overlander
Woodburn , Oregon
I wonder why I never get an answer to any of my posts ?
Old 07-23-2015, 09:07 PM   #3
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Bob, I have absolutely no idea what water pump I have in my '74, but it does a fine job, although it's just a little noisy. I'll look at it in the morning and tell you make and model...
-Red, just can't leave a brother hanging...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 07-23-2015, 10:29 PM   #4
1979 23' Safari
Wayland , New York
Just about any of the Shur Flow's will work good, any of their 3 GPM should keep you happy. SHURFLO 3.0 Revolution Water Pump gets good reviews. No need to spend $150+ like ive seen at the RV store. If you're replacing an original pump you'll probably have to do a little plumbing changes to get the new pump in. Consider getting the pump silencing hoses, and a small shur flow accumulator. The hoses reduce vibrations transmitted, and the accumulator reduces pressure surge in the plumbing and smooth's out and quiets the pump operation. Plus it gives some pressure surge volume for the entire trailer system.
http://www.amazon.com/SHURflo-4008-1...xgy_263_text_z
Another good pump,
If you want to splurge for a 4GPM pump, but it has some issues since it's a bypass pump, wants to run all the time, and if there's no flow instead of shutting off it recirculates the water back to its own inlet. So it needs some adjustment to get it working right.
http://www.amazon.com/Shurflo-404815...7B0X5C0MQ4AMNZ
Old 07-24-2015, 01:16 AM   #5
1974 Argosy 20
Kooskia , Idaho
Virtually all the RV pumps from Shurflo and Flojet work well. 3 Gpm is generally enough. I have not been impressed with the variable speed pumps. They cost a lot more and I have not seen them work much better. So, the low cost ones are fine.
Old 07-24-2015, 06:35 AM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I went with a very simple SurFlo Revolution pump 3 years ago. Appears to be bomb proof!
Old 07-24-2015, 06:55 AM   #7
KYAirstream's Avatar
Northeastern , Kentucky
Recommendations for the silencing hoses and accumulator?
KYAirstream is offline   Reply With Quote
Old 07-24-2015, 07:39 AM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Flex hose connections for sure, accumulator does little to quiet things down. Mount the pump on something resilient.
Old 07-24-2015, 03:17 PM   #9
1972 27' Overlander
Woodburn , Oregon
Thanks for coming thru guys.
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
