How not to check out the air conditioner: Only have a standard 3-prong house outlet? Don't use an adapter to plug in and run the AC. I visited to consider purchase of a pretty but sad Overlander once. Owner said he couldn't figure out why he'd replaced the AC twice. Yes, he had it plugged in to a standard house outlet (15 amp) with about 50 feet of extension cord -- double damned at the altar of insufficient amps and browned out voltage.
The trailer's power cord has a 30 amp plug. That's plenty of amperage to get the AC running. 20 amps probably would do it if you don't run the microwave or hair dryer at the same time. But 15 amps will subject the compressor to strain at startup and shorten its life. The RV dealer should have a 30 amp outlet and be able to show you the AC running.
With stabilizers down, stand on the rear bumper and jump up and down lightly. Have a companion look closely at the bumper-shell junction. You want to have no movement there. If there is movement, try to figure out what better floor inspection will let you get to the perimeter from inside the coach.
Be wary of cosmetic gussying up. "They all leak." (references too numerous to mention) There is a problem if there is any musty or off smell inside. BTW - that pretty Overlander? I'm allergic to black mold and I could hardly breathe after 5 minutes inside. It had huge floor rot issues under the front window, in the battery compartment and at the rear bumper.
