Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 04-10-2004, 08:44 PM   #1
pinkflamingoes
pinkflamingoes's Avatar
Profile:  1967 24' Tradewind
Alameda , California
Images: 40
Unhappy Wait! What about trailer width?
Wait...how wide are most airstreams anyway???
What if we can't even fit it in our driveway (10 ft. wide)?
I can tear out the brick planter on the side and it would be 11 feet wide.
Should I worry?
pinkflamingoes is offline   Reply With Quote
Old 04-10-2004, 08:48 PM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Cool Rest your mind
Should I worry?
If you're talking about a trailer~You'LL never have to worry about over-shadow that width`!
I honestly can't say for a MH..
ciao
53FC
AIR 807
53flyingcloud is offline   Reply With Quote
Old 04-10-2004, 09:20 PM   #3
j54mark
Profile:
The widest Airstream trailer is the current "wide body" which came along in 1996, I believe. They are 8'6", but I don't think that includes the awning arms. They were 8' wide for about 25 years before that, at which point you will have to get help from the Vintage Airstream people as I don't know.
mark
Old 04-11-2004, 12:46 PM   #4
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
59 is 88 inches wide at the floor. Door adds about 1.5-2 inches. I think that width is pretty standard for all models in that year.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 04-11-2004, 03:35 PM   #5
markdoane
Profile:  , Minnesota
Images: 59
My '59 is 90.67" at the widest part of the body about 40" above the floor.
Non-contributing deadbeat.
Old 04-11-2004, 04:26 PM   #6
overlander63
Rivet Masher
overlander63's Avatar
Profile:  . , .
My '72 is the standard width for Airstreams of that era, just under 8' wide, not counting awning arms. The awning arms on mine add a little over 4" to the width. With the drop step extended, it is around 8'6", but you have to have a little room to get in and out of the thing, say another 2 feet. So, 10'6" would be the minimum for most standard-width trailers, as far as being able to park and get around the trailer. The Argosy Minuets were 7'6", give or take an inch.
Something you didn't ask, but I will tell you anyway, the height on mine is 9'10", with no load in the trailer, over the A/C shroud. So, watch for low-hanging utility wires, tree branches, and eaves on the garage and house. The voice of experience here...
Old 04-11-2004, 05:48 PM   #7
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
I keep my 25' 'wide-body' Safari in a 10' wide spot behind our house. It was originally built for a sailboat with an 8'6" trailer. Although a little tight getting in & out of the A/S door while there, it works. Keep the planter, practice backing!!
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 04-11-2004, 10:39 PM   #8
pinkflamingoes
Images: 40
Ah, thank you. I didn't even think of height; we have no wires or tree branches to worry about, but the house eaves could be a slight problem. probably not though. Looks like I can get the A/S and keep the planter; and someone else will be doing the backing up.
Thanks everybody, I can relax again!
Old 04-11-2004, 11:50 PM   #9
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Wait! What about trailer width? Reply to Thread
Greetings airstreamhopeful!
There is an option available for a number of truck-based tow vehicles that can make getting into tight spaces a bit easier. My Airstream dealer offered to install a front receiver on my Suburban when I first moved to my current residence near the Quad Cities - - my driveway is bounded on one side by a utility pole and by a street sign on the other - - I had visions of not being able to hit the narrow window between the obstacles while avoiding traffic on the street which is the main approach route to our county hospital's emergency room. The idea is that by switching the ball mount to the front that it is easier to push the trailer into position rather than backing the trailer into position. As it turned out, I didn't find the positioning to be as difficult to maneuver as anticipated so didn't opt for the front receiver.
Good luck with your parking considerations!
Kevin
Kevin D. Allen
AIR #827
Old 04-22-2004, 08:12 AM   #10
ipso_facto
Profile:
I have the older 8' width, but for me, it is the length which makes it hard to maneuver. You have to be really good backing it in. I find myself having to stop, get out, look and drive - repeat that several times.
This isn't a compact car, these things are huge, in conjuction with tow vehicles.
1986 Excella, 32' - FOR SALE ON EBAY, AUCTION # 160034864277
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 04-22-2004, 06:11 PM   #11
overlander63
Rivet Masher
Profile:  . , .
Ah, thank you. I didn't even think of height; we have no wires or tree branches to worry about, but the house eaves could be a slight problem. probably not though.Thanks everybody, I can relax again!
Okay, I'll be a wise guy (like that is different for me):
The eaves will only be a problem once...
Old 04-22-2004, 06:39 PM   #12
pinkflamingoes
Images: 40
Absolutely! Like I said to my husband after my little fender bender, the day after we bought the car, "That pole had no business being there anyway!"
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 02:43 PM
Making a documentary about trailer life yoame Our Community 3 08-07-2003 09:21 PM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
Vintage trailer rally 83Excella The Rally Zone 0 08-13-2002 10:27 PM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 01:15 PM
