Old 05-18-2015, 11:52 PM   #1
Studio city , 91602
Upgrading Battery on 22 ft 2015 Bambi
Hello forum! I'm new to Airstream life. Recently acquired a 2015 Bambi 22ft and I'm looking to improve the battery life on my rig. I'm thinking from going one battery to two. Any advice on what parts I need , and what batteries would be best to buy?
Also would I need to upgrade my invertor (see photo ) Click image for larger version
Name:	ImageUploadedByAirstream Forums1432014702.788168.jpg
Thx!
BrandonG83 is offline   Reply With Quote
Old 05-19-2015, 04:40 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I don't see an inverter in there. Your CONverter should do fine with two batteries.
Changing out the incandescent bulbs for LEDs will help even more.
Old 05-19-2015, 08:11 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
You have a GR24 battery. I went from that to a GR27 then to a GR29. Needed to change the battery box. I am extremely pleased. More simple than two batteries and less weight on the tongue. I'm thinking you already have LED's?
Ahab is offline   Reply With Quote
Old 05-19-2015, 10:18 PM   #4
Studio city , 91602
Thank you Ahab, yes I have changed my interior lights to LED. I will take your advice on the larger (1) battery vs two. My other question , I have been charging my current battery to 13.6 what is the lowest I can go to before having to charge/ruin battery , a 10 ok?
Old 05-20-2015, 05:26 AM   #5
2016 30' Classic
Santa Rosa , California
Here's a good article on deep cycle battery charge levels:
Battery voltage and state of charge - Energy Matters
phann is offline   Reply With Quote
Old 05-20-2015, 01:33 PM   #6
1996 25' Excella
Tillsonburg , Ontario
As per the link from "phann"...10 is too low. 11.8 is a "dead" battery
When you drain a deep cycle battery completely (10V), you lose 10% of its capacity (do that to a car battery and it is 25% loss) and the loss is permanent. Do it again and you lose 10% of the 90% residual you had before, etc.
Certainly moving up to a size 27 is worthwhile and it should fit into your existing battery compartment. If you are really serious about dry camping then you can consider going to Two batteries but you then need to put one outside on the tongue. Or....you can go to AGMs that cost a lot more; they have more capacity but the second battery can go inside the trailer, since AGMs don't gas off explosive hydrogen.
JCW
JCWDCW is offline   Reply With Quote
Old 05-20-2015, 09:48 PM   #7
Kansas City , Missouri
I'm considering purchasing a 22 Sport and inquired today regarding upgrading to two batteries and the dealer said it wouldn't be a problem. He didn't provide any further details.
Steuart is offline   Reply With Quote
Old 11-15-2016, 11:43 AM   #8
2015 22' FB Sport
Indianapolis , Indiana
good afternoon. I am a newbie. We have used our 22FB about 6 times, but all on hook ups. How do I run lights, heat, etc. off the battery? Thanks for your help.
Jim Arnold is offline   Reply With Quote
Upgrading Battery Capacity Road Geezer Batteries, Univolts, Converters & Inverters 2 01-04-2012 12:23 AM
Upgrading a 16' Bambi with 3500lb GVWR ljmiii Axles 3 05-31-2009 04:18 PM
Battery tales – upgrading batteries for boondocking Safari SE hshovic Batteries, Univolts, Converters & Inverters 12 04-22-2009 01:50 PM
upgrading coverter - battery query jeftec Batteries, Univolts, Converters & Inverters 3 06-30-2007 07:40 PM
Upgrading batteries in a 2005 bambi CCD JDL Batteries, Univolts, Converters & Inverters 19 11-03-2006 12:55 AM
