Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 01-27-2004, 11:43 AM   #1
tin can luv
tin can luv's Avatar
Profile:  1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
Unhappy Tounge Weight?? 76 Overlander 27'
Help! I've been off line for more than two days! AHHH!
My aunt is searching for a vehicle to tow the 76 overlander 27' that we're rehabing for her, and she desperately needs to know the weight/tounge weight of the trailer.
ASAP would be good.
Yesterday, would be better.
May I never be off line again,
Ron
tin can luv is offline   Reply With Quote
Old 01-27-2004, 12:05 PM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Tongue Weight ?? 76 Overlander '27
Greetings Ron!
The 1976 Overlander has an empty weight of either 4,575 or 4,600 pounds with an empty hitch weight of between 500 and 550 pounds. Realistically, with options and personal belongings added the gross weight will likely approach 6,000 pounds with a laden hitch weight of 750 to 775 pounds. My '64 Overlander has very similar empty figures with a gross weight of 6,100 pounds and a laden hitch weight of 750 pounds.
I have towed the trailer with both automobiles and light trucks. While a small block V8 with the correct gearing CAN handle the chore, a big block V8 will be much better suited to the load. I currently tow with either a '99 K2500 Suburban (7400 VORTEC with 4.10 gears) or a '75 Cadillac Eldorado Convertible (500 cubic inch V8 and 2.70 gears). Each vehicle has its benefits, but the Suburban handles any kind of hilly terrain with much greater ease due to its gearing. My previous tow vehicle (before the Suburban) was a '95 K1500 Z-71 Extended Cab Pickup (5.7 Liter V8 with 3.73 gears), and it was not able to adequately tow the weight in the Rocky Mountains - - it was in Low gear at less than 20 MPH when we cleared the Eisenhower Tunnel on I-70.
The minimum tailer tow rating that I suggest looking for to tow an Overlander is one of at least 7,500 or better yet 8,000 pounds. My Suburban as ordered, came equipped with a 10,000 pound trailer tow rating while the Cadillac as ordered came equipped with a 6,000 pound trailer tow rating (one reason the Cadillac sees minimum usage with the Airstream is that I must seriously adjust my packing to keep the weight below its maximum rating).
Good luck with your search for an appropriate tow vehicle.
Kevin
P.S.: The following link will take you to the factory site with the Airstream trailer weights as well as other valuable information.
Airstream Weights and Measures
Kevin D. Allen
AIR #827
Old 01-27-2004, 12:44 PM   #3
tin can luv
1976 27' Overlander
Images: 82
Thanks again...
Thank you once again. I almost sent you the question directly. But I hate to bother you with all of my questions.
I can't thank you enough.
Ron
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
