Old 07-31-2019, 05:58 PM   #1373
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Has anyone seen this happen.
While at the Rally, we had decent city water... volume and pressure was great. Instructions said to arrive with holding tanks empty and a full fresh water tank. I stopped along the way and the tank was showing (based on the monitor) one light down from full.
Water pump was off... never turned on. There was no leaks.
After several days the fresh tank was showing around half full. I had not been drinking alcohol... at least not in excess. Ha
I know about the pump check valve failing that would fill or overflow the fresh tank from the city supply, but has anyone heard of the opposite happening?
I suspect that the issue is the inaccuracy of the monitor system. Anyone?
Clint
2018 Ford F150
2013 International Signature 23FB
A married man should forget his mistakes. There's no use in two people remembering the same thing!
Wolfwhistle is offline   Reply With Quote
Old 07-31-2019, 06:35 PM   #1374
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by Wolfwhistle View Post
< snip >
Clint
Probably so, Clint, the MicroPulse systems are famous for inaccuracies.
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 08-01-2019, 08:54 AM   #1375
Wolfwhistle
HILLIARD , Florida
Originally Posted by eagletoo View Post
Clint, if possible can you take some pics of your hw heater upgraded installation? I have a feeling I will see the same stock cruddy install that you saw.
Will do. Today
Old 08-01-2019, 09:04 AM   #1376
RFP
RFP's Avatar
Hurst , Texas
Will do. Today
Well, I'm not Clint, but here are a couple of posts to get you thinking...
http://www.airforums.com/forums/f142...ml#post2160008
http://www.airforums.com/forums/f445...ml#post2154429
And some stuff
Old 08-02-2019, 05:08 AM   #1377
Wolfwhistle
HILLIARD , Florida
With most cabinetry removed
Clint
ID:	348279   Click image for larger version
Old 08-02-2019, 05:59 AM   #1378
Wolfwhistle
HILLIARD , Florida
pcskier
My 225 Ah in series has just that, 225 usable.
Clint
I’m quoting myself to make a correction. I tried to edit a few hours after I posted the bad info but I had waited too long.
Correction: two GC-2s at 225 Ah are considered about 112 Ah usable when discharged slowly.
Oops
Old 08-02-2019, 09:27 AM   #1379
Wolfwhistle
HILLIARD , Florida
I sanitized after getting home and filled it. Read full. Odd. Thx
Clint
Old 08-02-2019, 09:33 AM   #1380
Wolfwhistle
HILLIARD , Florida
Anyone curious what floor looks like below the thin vinyl sheet? A band of black paint around perimeter and s cost of adhesives, which wasn’t holding many places on this 2013 model year. You can see butt joint fasteners and hefty flat square drive screws. Some evidence of sanding too. More than Forest River does.
I have some gently used blonde vinyl free to a good home. Too.
Clint
ID:	348297   Click image for larger version
ID:	348299   Click image for larger version
Old 08-02-2019, 09:36 AM   #1381
RFP
RFP's Avatar
Hurst , Texas
Clint
Clint,
The readings I get for our black and gray are usually pretty good... All my reading for the fresh water tank are odd!
And some stuff
Old 08-03-2019, 06:45 AM   #1382
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I was at the factory everyday for the two weeks it took build our Classic in January 2014, I watched a very disinterested chap with a bucket apply that black sealer to the edge of the plywood floor. He dipped the brush into the bucket about every ten feet. The color was barely there and no effort to apply generously to the edge of the plywood. So truly a lick and a promise for the first line of defense against water getting into the plywood.
Old 08-04-2019, 03:23 AM   #1383
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
Thanks for the pictures Rob. What you have done to your International is truly remarkable. You have a great talent. I have never heard of “Baltic Birch” until you came along . Thanks again for sharing.
Bruce
2020 23’ Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 08-04-2019, 04:29 AM   #1384
Wolfwhistle
HILLIARD , Florida
I like your WH hold down method, Rob. It looks like you needed about 2-1/4” of spacing while I needed 3-3/4”. This is making me raise the bed (s) platform a minimum of 1-3/8” higher to clear the WH. That’s also going to force me to go with about s 6” mattress because of the wardrobe cabinet. I could have reduced the height of that cabinet if I had realized it first.
Clint
2018 Ford F150
Old 08-04-2019, 04:34 AM   #1385
Wolfwhistle
HILLIARD , Florida
There are far better non rotting materials that could be used for the floors of these $70 - $150 K trailers. Might increase cost to build by $200?
Clint
2018 Ford F150
Old 08-04-2019, 06:41 AM   #1386
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Clint
Clint,
What flooring are we going to reinstall?
Dept of “OverKill”
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
