Old 07-28-2019, 07:15 AM   #1317
1975 29' Ambassador
2019 23' Flying Cloud
Beach Park , Illinois
Originally Posted by pcskier View Post
On his trailer, Airstream used separate cables from the batteries, one set to the 12V house (6ga) and one set to the inverter (4ga). If trailer was not equipped with factory inverter, there would have only been the one set, 12V house.
So instead of just interrupting one set of cables from the batteries with the shunt, he had two sets to interrupt...the inverter and house cables. Needed to include both cables from the batteries to the shunt, in order to have enough wire capacity to carry both house loads and inverter load. Then continue the original two wires from load side, one to the inverter, the other to house. So inverter draw and house draw will flow through the shunt.
On my install, I removed the 6ga and 4ga pairs when I did my 6V battery conversion, and went with 2ga wire from battery to the trailer; then 4ga from load side of shunt to inverter, and 6ga from load side of shunt to house 12v. The 2ga was installed so that I had enough capacity to carry both the house and inverter loads on one strand of cable. Doing it Leedav's way is easier and perfectly fine, but I decided to go a bit cleaner with less wires from the batts. Especially since I installed a switch that gives me four options: battery off, house only, inverter only, or both house and inverter. The second switch is to isolate solar panels from the solar charger.
Attachment 347776
Attachment 347777
OK Please bare with me as I went from a 1975 29' to this new 2019 23FB and I've been following this thread but I'm not sure I understand what the shunt is for or does. Do or should I put one in on my coach? Thanks John
51hunter is offline   Reply With Quote
Old 07-28-2019, 07:21 AM   #1318
2019 23' International
Portland , Oregon
The 23FB forum
The shunt is a resistor. It allows the monitor, which is basically a voltmeter, to measure the current flowing in and out of the battery. It's small resistance doesn't affect the power usage. Since voltage=current times resistance, the meter can determine by reading the voltage across the shunt how much current is being drawn, and by keeping track of that over time, how much power remains in the batteries. A battery meter therefore will only work with a shunt.
2019 International Signature 23FB "Cecil"
2005 Yukon XL
Former coach: 2015 Bambi 16 "Beanie"
leedav is offline   Reply With Quote
Old 07-28-2019, 08:42 AM   #1319
Portland , Oregon
Now thinking about closet shelves. From the battery meter exercise I now know that the closet walls are 33/64 thick, including the paper on each side. Click image for larger version
2005 Yukon XL
Old 07-28-2019, 10:04 AM   #1320
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
John, congrats on the upgrade. She shunt is if you wanted to install a more robust dedicated battery monitor such as the Victron that Leedav used. It accurately will display battery voltage like the OEM systems monitor on the panel does, but also allows for an accurate reading (because of the shunt) of amps being used and some other metrics, which is helpful for battery management when boondocking or non-hookup campsites. (No shore power hookup). All negative loads go through the shunt to accomplish this.
Definitely not required, but a 'nice to have'.
Many of us have added in conjunction with a solar installation. I did, because it's helpful to see the 'net amps' flowing to or from the battery based on various power draws and solar production input. If the meter shows a net of 0 amps...the sun is keeping your batteries at par. If negative...you're using less than you're producing, and if positive...your producing more than you're using. Just sort of a window to know what is happening overall, with an eye to conserving battery power while not hooked up to shore power.
pcskier is offline   Reply With Quote
Old 07-28-2019, 10:12 AM   #1321
pcskier's Avatar
Park City , Utah
Read through the 23d thread as well. You'll be thinking about a lot more than just closet shelves, I promise you that!
Old 07-28-2019, 10:21 AM   #1322
Portland , Oregon
I'll try to hold off.... My track record so far is not good.
2005 Yukon XL
Old 07-28-2019, 10:26 AM   #1323
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
The 23d thread is totally addictive (and humbling) - with the most knowledgeable, unselfish members you will ever meet. Just awesome!
Bruce
2020 23 Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
Id rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 07-28-2019, 10:27 AM   #1324
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Adopting the motto, "build it, use it, change it". I really don't like what I did in place of the dinette (23FB has the huge wheelwell to deal with for our non-regular thread visitors).
Mine is a 2013, so the dinette has benches of formed plywood facing each other and a wall mounted table top that swings down (extension leg) to allow a bed to be made there. It would be for kids or maybe one adult.
I loved the huge countertop that I made and sitting there with the great view. But, there is simply not enough space for the office chairs when more than myself is using the space. So, it is all gone.
I thought about putting the original bench seats back but cutting them down and going to a small top and possibly getting the newer type top support. Pro would be the added clearance to the fridge door, but it would only sit 2, and maybe a kid or two. Really no different that what it would be not cut down.
I've thought about building a dinette seat along the wheel well top and table in front. I would be sitting looking at the kitchen / stove / fridge, etc. But, 4 could sit there and it would make a nice possibly, full size bed. The wheel well box, by the way it 80" long.
Another option would be a jack knife sofa bed. My concern there is most only go up to 72" long. and typically 43" or so wide.
If I build that long bench seat, that would require cushions to be made to do it right.
Another modification that I will probably make is to replace the east-west short queen with twin beds. I see a lot of work, but think it would make the trailer work very well for us.
Thoughts?
Clint
2018 Ford F150
2013 International Signature 23FB
A married man should forget his mistakes. There's no use in two people remembering the same thing!
Wolfwhistle is offline   Reply With Quote
Old 07-28-2019, 10:46 AM   #1325
2014 23' FB Flying Cloud
Yamhill , Oregon
So I just installed the jumpers that allow me to check the levels in my battery, because for some reason airstream gives you a little short ones that don't let you open the caps. Both batteries have a bad cell at the end, which is probably contributing to my issues. Good news is the pd4655 just arrived
Question for the group. Installed the PD4655 about a year ago but not the new fuse block because the battery leads are too short. Is there any way to install the pendant without using the new fuse block?
Rob Edgerton is offline   Reply With Quote
Old 07-28-2019, 10:52 AM   #1326
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
51 - you do not need the shunt/monitor upgrade if your use is mostly FHU park stays. If you use the coach for mostly dry camping, you may find the more precise measurement of the BM helpful. Most folks install a BM as part of an electrical upgrade like solar as PC posted above.
But in any case, verify you have fresh un-wounded batteries in your bank. Often a new coach is towed to the dealer and the batteries are allowed to be pulled down by the parasitic loads and incidental use to a state of charge that kills a cell or two. Folks find the bank to perform poorly upon initial pickup.
Have Interstate check your batteries and replace them under warranty if necessary. Then never allow the bank to discharge below 12.2 Volts. That is a bit touchy as it required the bank to rest under no load or charge to get an accurate reading. However, close is really good enough.
Disconnect the batteries when in storage. Parasitic loads (LPG detector, lights left on, standby electronics) continue to pull power even in the store mode (use/store switch). Some folks add a disconnect switch to make the process easier.
Best to use what you have and learn what you want before starting major projects. Enjoy the new coach. It's well featured and many of us are trying to catch up. Hope to see you and the shiny down the road. Pat
Old 07-28-2019, 10:57 AM   #1327
eagletoo's Avatar
Clint, you might have seen this twin conversion already but just in case you havent, check this out.
https://youtu.be/jsIMXDV8TZE
Bruce
Old 07-28-2019, 10:58 AM   #1328
PKI
PKI's Avatar
Originally Posted by Rob Edgerton View Post
-- snip --Question for the group. Is there any way to install the pendant without using the new fuse block?
Believe the pendent plugs into the main unit. Call Best Converter for instructions if it is not clear from looking. Note, the OEM fuse board has better wire clamps, so it is best to install the unit as you did.
Clint - you need a 27! The dinette is a fact of the layout. Best for the space. You can change it, but improvement really takes a different trailer. Twins should make the sleeping area a bit better space, but have their disadvantages.
Nice to see everyone making functional changes. Keep up the good work. Pat
Old 07-28-2019, 11:00 AM   #1329
Wolfwhistle
HILLIARD , Florida
I completely agree, eagletoo. The 23D and this one have some of the kindest and knowledgeable members that I have encountered on a forum. It is quite amazing.
Clint
2018 Ford F150
Old 07-28-2019, 12:13 PM   #1330
pcskier's Avatar
Park City , Utah
Whoops. If negative, you are using MORE than the sun is producing. I said that wrong.
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
