Old 09-26-2019, 04:08 PM   #1561
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by GettinAway View Post
My AC drip has stopped up over the last few days. Was working fine until yesterday. The water is now coming forward and off the curb side front corner. Guess Iíll have to find that drain up in the AC that Iíve seen mentioned.
Attachment 352954
Good afternoon!
Here's a fairly lengthy - and comprehensive - thread on this very problem. Read the whole thing and you will earn your doctorate in up-fixin' der drain!
http://www.airforums.com/forums/f427...be-182389.html
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 09-26-2019, 05:34 PM   #1562
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
This is not really a reply but a revisit of a covered topic. I have a 2010 Flying Cloud 23 FB. I need to replace the tires and am interested in going to 15 inch wheels and tires. My wheels have 5 studs. Can someone who has done this tell me what I need to get. I was thinking of perhaps checking with Tire Rack for prices. Thanks, Cameron
curnes is offline   Reply With Quote
Old 09-27-2019, 04:56 AM   #1563
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Originally Posted by RFP View Post
Good afternoon!
Rob
Thanks Rob. I remembered that you had done this, but wasnít sure if it was in the 23CB thread or separate. I was worrying last night that running it like this for a week was probably not a good idea. Hopefully water isnít working itís way inside of anything. Itís just going to have to wait. The humidity here is unbelievable (I guess it should be humid we are 100 yards from the Atlantic Ocean) the water is pouring off the roof when the AC is running. Which was non stop yesterday. It wasnít supposed to be in the 90s here in late September.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 09-27-2019, 05:52 AM   #1564
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
My preferred source would be eTrailer, then Discount Tires (in my area is a good store) and certainly Tire Rack.
The wheels are 5 on 4-1/2" centers. 6" wide with 0 offset. These can be found in 14 and 15". The factory wheels are Sendel T02 or T03. But, you can get other wheels that fit, so it depends on what you are going for.
My 2013 came with new 14" GYEs, but when the time comes I am switching to 15", and haven't decided to go Michelin, Goodyear, or some other brand. I am liking these GYEs.
If you ask 10 people about this you could get 10 different answers. But here is a thread that covers it pretty well.
http://www.airforums.com/forums/f438...-a-145874.html
Clint
2018 Ford F150
2013 International Signature 23FB
A married man should forget his mistakes. There's no use in two people remembering the same thing!
Wolfwhistle is offline   Reply With Quote
Old 09-27-2019, 07:04 AM   #1565
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
From a prior post of mine
The curb side wheel well on our 2015 23D International Serenity had more sheet metal in front of the 14" tire than the street side (another manufacturing defect) wheel well.
Going from the stock GYM ST215/75R14C tires with a diameter of 26.7" to the Michelin LTX (P) 235/75R15 XL tires (mounted on SenDel T03-56445T wheels) with a diameter of 28.9" meant these tires were about 1.1" larger in diameter. We trimmed the front edge of the curb side wheel opening to have the same dimension of skin behind the vertical plastic wheel well as the street side and the tire fits fine.
We are converting from the Dill1506-453 TPMS system (due to age of the batteries) to the Tuson TPMS system with a color display that is actually readable. We also installed Centramatic 200-221 standard part wheel balancers and McGard 24138 Chrome Cone Seat Wheel Locks and McGard 64010 Chrome Bulge Cone Seat Style Lug Nuts (1/2" - 20 Thread Size).
Note that the larger tire diameter necessitated building a brand new spare tire carrier. We also upograded to 10" auto adjust brakes.
The trailing arm suspension Airstream uses means that the wheels travel up and back when a bump is hit.
Also, this tire brought the 23D frame to the same elevation as our 2013 25FB International Serenity that was traded in on our Classic. The 25FB had a Hensley Arrow hitch that we reused on the 23D.
Old 09-28-2019, 06:11 AM   #1566
GettinAway's Avatar
I agree with Clint. eTrailer was where we bought the wheels. We ended up getting the exact same style wheel as the factory 14s, but in a 15Ē. I went to auto tire near me in MO for tires. They matched the Tire Rack prices, and did the mounting and balancing. I had to mount the tires and wheels on to our 23FB myself. That was easy with a ramp. Sold the old tires and wheels on Craigslist. Iím very happy with the GY Endurance tires so far.
2011 FC 23FB
Old 10-01-2019, 10:37 PM   #1567
curnes's Avatar
Thanks for the wheel/tire tips.
Old 10-02-2019, 03:31 AM   #1568
DougHeff's Avatar
South , Alabama
Originally Posted by Wolfwhistle View Post
Call me irresponsible. Iím fed up with the door slamming open then latching automatically. Surely the new ones have blue tooth that you control with a smart phone. But for simplicity sake. This is my strap solution. Of course it depends on the main and screen door staying latched together. Certainly not original, but Iíve not seen one on an AS.
Clint
Great idea! You must own a Jeep?
DougHeff is offline   Reply With Quote
Old 10-02-2019, 01:01 PM   #1569
1975 29' Ambassador
2019 23' Flying Cloud
Beach Park , Illinois
Well took the AS to the dealer for a new rear camera. Old one full of water. After taking the old camera bracket off and lots of pulling on the wire and probing the mechanic finally pulled/ broke the wires.
Now to find power he removed the center and passenger side running lights above the camera. Finally got 5 inches of wire out and spliced in the new camera wiring harness.
Then with lots of sealent put it all back together. Only took 2 hours.
Now I covered it with a plastic baggie and taped it leaving the bottom open. This spring I'm going to make a cover/schroud out of aluminum to prevent further moisture problems. The dealer said he does about 3 cameras a month.
John
51hunter is offline   Reply With Quote
Old 10-02-2019, 09:35 PM   #1570
2017 23' Flying Cloud
Bartlett , Tennessee
Does anyone else have my problem?
The 3 white screws holding the overhead bins above the stove to the wall beside the microwave keep coming unscrewed, and falling out.
AND
The 3 white screws holding the overhead bins above the dinette to the wall of the clothes closet keep coming unscrewed, and falling out.
The same 3 white screws in both locations.
Any solutions?
(After driving 60 miles, I have to tighten them all. One of them is already out about 3/16" in that short a drive.)
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 10-03-2019, 05:27 AM   #1571
1975 29' Ambassador
AND
Any solutions?
I would try using either lock tite or carefully use JB weld on the screw tip to lock it in place
Old 10-03-2019, 06:04 PM   #1572
Since it is a sheet metal screw into the wood paneling, JB Weld for Wood is a brilliant idea. Thanks.
Old 10-03-2019, 06:49 PM   #1573
2017 27' Flying Cloud
Fort Worth , Texas
Attachment 352954
Let me know if you find the drain in the A/C. My front A/C has never drained down the tube. I have looked in the A/C, but have not located the drain. Have tried trimmer line on a drill to clear the tube, but t seems to run into an obstruction.
billrector is offline   Reply With Quote
Old 10-04-2019, 07:58 AM   #1574
1975 29' Ambassador
Hope it works. Your welcome
Old 10-06-2019, 05:44 AM   #1575
GettinAway's Avatar
Still out and about. (Indiana state park last night) The weather finally cooled off! I hope to look at this later in the week.
Thx
2011 FC 23FB
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 03:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 02:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-11-2012 11:29 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
