08-29-2019, 07:55 AM
#1461
2019 23' International
Portland
, Oregon
Originally Posted by Wolfwhistle
My unit has a factory Varistor connected to the outside condenser fin... still there; not being used now. 115 on and 90 off, is higher than I want... I think I set this for 30C/26C (on/off), not sure what is ideal. If hooked up, why not just switch them on all the time. It can't hurt and they are designed for continuous use... boondocking you would want to save every Ah you can... 0.42 amp each would be 10Ah a day or 20Ah for two, continuous. I need to figure out what the converter and thermostat use (parasite load) when fans are off.
Clint
Always on is ok. That’s what the Bambi did essentially. Once I took out the factory noisemaker and put in a Noctua it was all good. I’ll collect all the bits over the next week as I decide the approach.
Wife and her friend are doing a Bike and Barge in Idaho starting the 7th for about a week. I’ll be the land barge driver and camp b**ch. need to either finish by then or not start until after.
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
08-29-2019, 12:06 PM
#1462
Portland
, Oregon
Found the thermostat right on the side of the fan. First step, replace it since the fan didn't come on yesterday. 115/125F replacement should arrive tomorrow. I had an extra one from the Bambi, it was 50 degrees F!
08-29-2019, 12:14 PM
#1463
Portland
, Oregon
One more thing. Wolfwhistle.. the supply side to the fan thermostat is regulated to 12v by the refrigerator control circuit board, it seems.
08-29-2019, 12:17 PM
#1464
Portland
, Oregon
And... Pat... the circuit board in the subwoofer enclosure is the awning controller
08-29-2019, 02:21 PM
#1465
1975 29' Ambassador
2019 23' Flying Cloud
Beach Park
Clint
I got my fans. How did you figure out which wire is + - or light ?
John
08-29-2019, 02:47 PM
#1466
Wolfwhistle
Margaritaville
, Banana Republic
Originally Posted by 51hunter
Clint
John
Do you see 2,wires popping thru the outside wall between the vents?
08-29-2019, 02:57 PM
#1467
Portland
, Oregon
I thought he was asking about the fan pinout
08-29-2019, 03:32 PM
#1468
Wolfwhistle
Margaritaville
, Banana Republic
L, oh. From memory. You see the large plug. I think those are the 2 wires you want. One of the three isn’t used. Don’t know it’s purpose. The center is 12v +. The other ground. I cut off the small plug. LEDs are on when the fan is on, not independent. The AS wire color is red + and yellow (-).
Clint
Is taking it all with you, really getting away from it all?
08-29-2019, 03:47 PM
#1469
1975 29' Ambassador
Beach Park
Clint
Yes I was talking about the fan. I just got them today and with no color code WTF I read that its +12vdc -12vdc And a light for the fan. I'll experiment to see. Thought you might remember but not a problem. Working with low voltage is easy but without colors ???
Thanks to both for the info John
08-29-2019, 03:48 PM
#1470
Wolfwhistle
Margaritaville
, Banana Republic
I eliminate the USE / STORE panel. Covered with a piece of Laminate that was salvaged. I’m making an addendum for future owner or me if I forget (ha) how to manage the disconnect switches beside bed. Thus how to store or use. I can cut all power, have converter without charging battery, or charge via converter, or charge via solar, or charge with both. Inverter can also be disconnected from battery power. On DC and AC sides. I think I showed how I used a 50 amp panel to serve as main (30a) and subpanel (30a) via auto transfer switch. Here it is if I only thought I did. Notice the remote fob isn’t used with LFP.
Clint
08-29-2019, 03:51 PM
#1471
Wolfwhistle
Margaritaville
, Banana Republic
Yep. There is a dot code. But with a computer it’s plug and play.
Clint
08-29-2019, 06:34 PM
#1472
Portland
, Oregon
08-30-2019, 03:11 PM
#1473
Portland
, Oregon
And done. Nothing crazy. Replaced the factory noisemaker with a Noctua. Had to grind down the bracket a little bit because the new fan is thinner. Replaced the thermostat with one that is working at a normal temperature and we are good to go
08-30-2019, 06:26 PM
#1474
Portland
, Oregon
And I was wrong about the wire to the thermostat. Yes it was at +12.0 and yes it was from the control board, but it is an input and wouldn't be appropriate to drive the fancy thermostat. The mechanical thermostat shorts it to ground, which means it's just a logic input.
09-01-2019, 11:36 AM
#1475
2018 28' International
Liberty Hill
Kittens
We just got two kittens and they discovered the hole in the bathroom next to the toilet. Has anyone blocked this space?
09-01-2019, 11:48 AM
#1476
Walnut Creek
Not sure if it's your hole, but the one in front of the riser close to the floor holds a 4 pack of TP. Pat
09-02-2019, 05:20 AM
#1477
Wolfwhistle
Margaritaville
, Banana Republic
Originally Posted by leedav
Pretty cool, leedav. I might go with that 60s motif, but I know someone that would hate it... lol. I have to do something to this way too much and too dark laminate cabinetry. I've ordered some peel and stick wallpaper and will see how that goes. I wanted to buy custom coverlets in some pattern for the twins, but couldn't find anything we liked. We got a white quilted king-size coverlet and after cutting in half, sewed it to fit the new twins. Looks good for not a lot of money, IMO.
Clint
09-02-2019, 03:59 PM
#1478
SR
2014 23' FB International
DFW
23FB à la "The Jetsons"
An Airstream should have a touch of personality. You’ve added the perfect amount!
09-02-2019, 04:04 PM
#1479
Portland
, Oregon
Thank you both. Full disclosure... Wife's work. I just fix and install stuff
09-02-2019, 11:11 PM
#1480
2017 25' Flying Cloud
Antelope
This is wonderful! Great personality.
