Old 01-15-2019, 09:56 AM   #981
Wolfwhistle
Wolfwhistle's Avatar
2013 23' International
HILLIARD , Florida
Hi Janice! Welcome to this wonderful forum. There is a 23D group (link below) and since these two models have so much in common... it is also good to be a part of. What they do over there is amazing.
First page...
http://www.airforums.com/forums/f142...ad-166085.html
Home Remedy is a 2013 IS 23FB. Tow vehicle is now a 2018 F150
Wolfwhistle is offline   Reply With Quote
Old 01-15-2019, 10:15 AM   #982
2018 23' International
Centennial , Colorado
First page...
Thanks, WW --- I have read the whole of the 23D thread, along with this one (whew!). I have crossed fingers that I will have no issues but if something should happen I feel confident the answer will be found between these 2 forums.
Janice
2018 23FB Int’l Sig
2017 Jeep Grand Cherokee - Hemi
#9430
Jdubya is online now   Reply With Quote
Old 01-15-2019, 12:48 PM   #983
Portland , Oregon
Fresh Water Tank Housing/Panel Leak
Hi all,
New Airstream owner here--
I purchased a used 2013 23' Flying Cloud and have been enjoying it for a couple weeks. Days into using it, I noticed that my fresh water tank was leaking. Not only was it leaking, but the aluminum housing seemed to have been bowing the more full my tank got.
Brought it back to the dealer for their 30-day warranty. Said that it was just a line that was leaking but would not change the aluminum housing.
Is that something to be concerned about? Should this aluminum housing be replaced or would any of you suggest that it's fine as-is?
Thanks!
nicobau is offline   Reply With Quote
Old 01-16-2019, 08:13 AM   #984
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Nicobau
I don’t like leaks. I guess if it’s a drop every few minutes, maybe I’d be able to live with, but I’m not sure about that. I have to admit, I’m not sure if my freshwater tank sags down when full. We more often than not don’t have a water hookup so we use the tank a lot. I’ve never noticed and change in its shape, but never really looked for it either. I’m fully winterized now, and we are expecting single digits in the weeks ahead, or I could check. Hopefully your dealer will step up.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 01-16-2019, 01:16 PM   #985
Portland , Oregon
GettinAway,
Thanks for your input! The dealer fixed the line that was leaking. I was just shocked that his warranty wasn't going to cover, what looks like, a faulty aluminum tank housing.
Old 01-16-2019, 03:09 PM   #986
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Originally Posted by nicobau View Post
Hi all,
Thanks!
There should be some additional straps under and around you tank shroud! Mine has 4 straps that help support the weight of the water in the tank.
See attached pic.
ID:	331848   Click image for larger version
Dept of “OverKill”
Old 01-16-2019, 03:15 PM   #987
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
If the dealer will not repair the distortion, it would be a good idea to find another way to correct the damage. Some patina can be ignored, but it's not really a good idea to let stuff hang below the normal belly datum. Pat
Old 01-17-2019, 12:00 AM   #988
Portland , Oregon
See attached pic.
That's amazing, thanks for sharing. I'll pass this photo on to the dealer, hopefully they can emulate that. Thank you!
Old 01-17-2019, 06:21 AM   #989
Overkill Pundit
GMFL's Avatar
Dadeville , Alabama
Those straps are factory standard on my unit. Yours should have had them I would suspect.
Dept of “OverKill”
23FB thread/forum seems to be missing? PKI Forum Admin, News and Member Account Info 18 05-24-2018 04:17 PM
New to the Forum Looking at 23FB and new Tow Rig SYC2Vette Member Introductions 2 04-17-2017 03:51 PM
Forum Feedback... What do you think of this forum site? Andy R Our Community 37 04-12-2012 12:29 AM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 12:12 PM
